| Chip Amps Amplifiers based on integrated circuits |
A value of 10K is often suggested but I could only find a 100K value.
Safe to use? Alan |
#2 |
sure
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1 |
#3 |
Hi Hotscot,
How have you assembled your chipamp? inverting, non-inverting, DC block on NFB, DC block on input, Zin, NFB resistor values, All the above will affect the DC output offset and they interact with what source impedance/resistance the amplifier input sees. If you want to use a passive attenuator then Zin>=5times the attenuator resistance. attenuator resistance >=5times the source resistance. 5times is the minimum, but 10times is better. A disadvantage of using high attenuator resistance is loss of treble from the amplifier. Careful selection of component values can avoid many of the problems.
regards Andrew T. |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| Volume control for lm3875 amp | Arx | Chip Amps | 10 | 23rd September 2007 09:25 PM |
| lm3875 inverted layout with 100k pot, not enough volume? | rocktboy | Chip Amps | 11 | 12th January 2006 05:44 PM |
| LM3875 into 4 Ohm | audioPT | Chip Amps | 12 | 7th July 2005 12:14 AM |
| LM3875 amp | Tekko | Chip Amps | 2 | 20th January 2005 04:32 PM |
| Page generated in 0.24791 seconds (25.51% PHP - 74.49% MySQL) with 10 queries |
