| Chip Amps Amplifiers based on integrated circuits |
#121 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#122 | |
I should have looked carefully at the diagram myself. I couldn't find 91R resistors, so I am using 100R's. That is, 100R + 2.2k and 100R + 1k. Sorry for the confusion! EDIT: For the power amp I am using 'commercial' metal cased bridge rectifiers, not MUR860's, and multiple 2200uF caps, not a single 4700uF. For the pre amp I am using 1N4007 DIY rectifiers (a possible source of error, so picture attached) and multiple 680uF caps. Diodes on all regulators I have used 1N4007's.
#123 | |
#124 | |
#125 |
that 10k dummy load you first tried is not as bad as first feared. The 100r draws 12mA through the reg + another 1.5mA/2.8mA through the dummy load.
regards Andrew T. |
#126 | ||
I am still confident that if someone else were to actually try what I am trying, with one supply set to give different voltages than the other, you would no longer be saying you know it is "correct" and you would see for yourself what I am seeing. For a single supply, yes, I totally agree. It works absolutely fine. It is correct. Until I tried with one supply giving different voltages, yes, both supplies were measuring correctly and I was none-the-wiser, even though they were apparently indeed "wrong", as BWRX has explained. I am indulging in this debugging process because I know full well I am capable of error (being "only human" after all), very very likely even more suspectible to error being a newbie, you are also after all the experts, and [I like to think] I have an open mind. From what I gather you have accepted, after BWRX's explanation, that the first diagram was in error. I can understand why it is hard to accept that I am still seeing the same behaviour, even after implementing his initial solution. You obviously have respect for BWRX. I can tell that he certainly has far more electronics knowledge than I, and so I can understand fully why this would point to an error made by me, rather than by him. It is far more likely I made the error. At the same time, I know BWRX is, as I am, also capable of error, and that an explanation of the problem doesn't necessary mean the initial solution is correct. I've often thought I had a solution to a coding problem, and it didn't work as I expected. As I have said before, I don't care if I am "wrong". I even hope I am wrong about all this. I hope it's a wiring error, or some other error on my part. I hope it's possible to do. Quote:
#127 | |
Ah, ok. Good to know. This would probably explain why, without the dummy load and individually I was seeing the correct output voltages then? I will still measure voltages of caps and rectifiers as soon as I can. |
#128 |
OK Markie, you seem to have a problem with me trying to help, so I'll bow out now and hope that Andrew can help you sort out this problem.
Good luck!
#129 | |
It is more a problem (possibly just to do with my personality / mentality or something and nothing to do with you at all) of insisting that I am wrong without any thought at all that BWRX's solution is actually at fault, and we don't know why yet. The stress effect I am currently experiencing from such an apparently harmless post may have been amplified by previous "****-taking" / winding up. If I have reacted inappropriately I hope the mods will sort it out. I'm not too good with stress. Anyway, as I said, I can certainly see why it points to me being wrong, Andrew also thinks this should work, and I'm not giving up in the debugging process and trying to find out where I might be wrong ![]() I will certainly quite happily try any suggestions you might think of, but if I have scared you away then thanks for the luck. I might also add that without you hassling we wouldn't have known I was using 100R resistors, and this helped Andrew. It is certainly good that you nitpick and you going would be a loss to the thread. Should the thread come to a conclusion and you no longer follow it, I will shoot you a quick PM so you can read it and, if it wasn't just an error on my part, update your site. |
#130 | |
diyAudio Moderator Emeritus
Hey guys, let's all just calm down. It's too early in the morning for me
![]() Quote:
From what mark has explained thus far I do not think he has miswired anything. Clearly the regulators for the negative rail are interacting because they share the same secondary even though they are isolated by separate bridge rectifiers. I didn't get a chance to think about this last night and probably won't again until the weekend. Luckily others are willing to help out as well! Until then, using a different transformer with dual secondaries for the preamp regulators will definitely, without a doubt work and is a better solution. Another option would be to use positive regulators for the power amp rails and then use a positive and negative regulator for the preamp rails. That will also work.
Brian |
| PC Power Supply Mod - Quick question for someone with an EE etc. | calee4nyaboy | Parts | 7 | 31st December 2009 06:10 PM |
| How much capacitance in a power supply | TugaTweaker | Tubes / Valves | 2 | 29th January 2006 05:40 PM |
| Power supply capacitance | winslow | Pass Labs | 5 | 13th August 2005 02:54 AM |
| Too much capacitance in power supply? | G | Tubes / Valves | 12 | 15th February 2003 02:08 AM |
| Power supply and capacitance.... | Lisandro_P | Solid State | 10 | 8th November 2001 04:15 AM |
| Page generated in 0.13215 seconds (81.73% PHP - 18.27% MySQL) with 11 queries |
