| Chip Amps Amplifiers based on integrated circuits |
#101 | |
(I was going to edit the last post to include this info, but the time limit expired sometime between clicking edit and pressing save changes, sorry! Since this has gone on a new page I will quote the previous info too)
The bridge inputs look identical as expected. A sine wave. The cap outputs seem fine, it showed as a straight line until I went down to ... somewhere.... between 10-100mv/div (I didn't note what setting I was using sorry, but can do it again if you wish). Here I started to see a very very very tiny thing like this: |\|\|\. Very small in amplitude, and as far as I am aware normal (cap charging and discharging?) The output of the preamp regulator was normal, again flat lines with a small hint of |\|\|\. The +ve rail on the power amp regulator also showed this behaviour. The problem rail, the -ve rail on the power amp which is giving -12.6v, I am seeing a really very large version of |\|\|\|\. I didn't note the setting again, but I believe this was visible around 1v/div. I can test again and note the setting if required, but I am off to eat for now! |
#102 |
It seems like the bridges don't quite isolate the supplies. I switched secondaries around on the preamp supply (just noticed I had the preamp negative fed from secondary #2, but power amp negative from secondary #1) and I see similar behaviour to before.
The power amp supply then turns normal +-28v, the preamp positive rail is OK at +13.6V, but the preamp negative rail initially shoots up (down?) to -28v, and then very slowly decreases. It went down to -18v pretty quick, then got really really slow (to the point where it seemed like it had stopped decreasing). |
#103 |
put a dummy load resistor across each of your regulated outputs, no connections to any ground or earth. Just to ensure each regulator has a real load. Measure and post the input and output voltages.
regards Andrew T. |
#104 | |
I can try a lower value if necessary, of course, but individually both supplies show the correct output voltages without any load. ![]() Looking at it I think I can fit the smaller transformer in there just about should this not be possible to do for whatever reasons.
#105 |
Any ideas?
I'm kinda tempted to try, today, and fit the separate preamp transformer and go with a single regulated supply (or even unregulated, don't which would be a better idea yet) for both power amp channels... |
#106 | ||
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#107 | ||
) all off the same transformer.Quote:
#108 | |||
What we really need to see is a circuit diagram showing exactly how you have this amplifier set up, wiring and all. While Brian came up with an explanation for that 'middle' circuit not working, it's strange that it doesn't work with the extra pair of bridges.
#109 | |||||
I was just asking if anyone had any further thoughts on any possible solutions to the problem, before I dismantle it and put in a separate supply for the preamp / take out one of the power amp regulators, since I seem to be the only one who can test possible solutions to the problem at this point. Quote:
I have tried with a load, and I even posted this. (i'm not sure if it was *enough* of a load, and I was hoping for feedback on that). Given it was the same as without a load, I did not post voltages. Saying that "it was the same" should be quite enough, no? There was really no need. I am guessing you just missed this post...? What other information haven't I come up with that you would like? It is possible I have missed something too. Quote:
I'm not sure if I should leave the regulated supply '0v' lines to safety ground / the disconnecting network, or leave them 'floating. In Andrew's post he said not to and BWRX's post seemed to imply it didn't really matter? Quote:
#110 |
I'm thinking of a dummy load like 500r not 10k which draws a current of less than the manufacturer recommends as minimum. +-28V into 500r gives +-56mA Pd~=1.6W (three 1500r 600mW in parallel). +-15V into 500r gives +-30mA Pd~=450mW (one 510r or 470r 600mW). Fit, measure and post. Can you take and post those pics yet? Common transformer into separate rectifiers into separate regulators will work. I still think there is a mis-wire somewhere. edit: typed 50r and now changed to 500r.
regards Andrew T. |
| PC Power Supply Mod - Quick question for someone with an EE etc. | calee4nyaboy | Parts | 7 | 31st December 2009 06:10 PM |
| How much capacitance in a power supply | TugaTweaker | Tubes / Valves | 2 | 29th January 2006 05:40 PM |
| Power supply capacitance | winslow | Pass Labs | 5 | 13th August 2005 02:54 AM |
| Too much capacitance in power supply? | G | Tubes / Valves | 12 | 15th February 2003 02:08 AM |
| Power supply and capacitance.... | Lisandro_P | Solid State | 10 | 8th November 2001 04:15 AM |
| Page generated in 0.14853 seconds (82.33% PHP - 17.67% MySQL) with 11 queries |
