| Chip Amps Amplifiers based on integrated circuits |
i will be running my lm3886s off of a switching psu which also has 3V and 5V outputs. i was planning on using the 3V to seperately power LEDs and such, and i was wondering if anyone knew of a simple buffer that would be happy running off of a 5V supply?
#2 |
There are many Opamps that you can use as a Unity Gain Buffer that can run off of Low Voltages.....
Like maybe a LT6202 or even the TL081.... You can even use some Transistors or Fets as a Buffer which will hapilly run at low Voltages...It would probably be better if your Supply can supply +/-5v so you don"t have to worry about Bias Voltages or DC Offset..... Good luck
#3 | |
Not realy. remember that the buffer, even a TL072 will not swing to rails, in fact it will go to rail less 1 volt. If you have only 5V the maximum signal out of the buffer will only reach 3V p-p before severe gain compression. Overdriving this preamp will be to easy, you need more headroom. My opinion only. Ciao Nico |
#4 |
You can turn that 5v into 15v if you use a Voltage Tripler...
This should explain how to do it.... http://www.play-hookey.com/ac_theory...ltipliers.html Just make sure that the 5v you are getting is has a LOT more current that you need because at Tripple the Voltage you will have about 25% the current available..... Just a Thought.... |
#5 |
Just build a simple shunt regulator, 1 to 1.2K ohm resitor and zener diode and some filtering.
#6 |
i would totally do that, if i knew what that was.
#7 |
basicaly a voltage divider made up of a zener and resistor in series... to set voltage and current... not ideal, but better than nothing.
#8 |
#9 |
#10 |
I agree... unless the 1k1 is dropping another 11V
| PCB design of parallel of two inverted LM3886 with buffer and dc-servo. | Roushon | Chip Amps | 74 | 11th April 2012 11:17 AM |
| LM3886 IGC + Pedja Rogic JFET Buffer | andreszibert | Chip Amps | 32 | 20th July 2009 12:33 PM |
| valve buffer with chipamp.com lm3886 | juluska | Chip Amps | 0 | 12th January 2009 10:09 PM |
| LM3886, XO, Buffer and Servo | jackinnj | Chip Amps | 3 | 30th October 2008 12:14 AM |
| Page generated in 0.11847 seconds (72.73% PHP - 27.27% MySQL) with 10 queries |
