Old 16th January 2007, 10:59 AM   #1
jaste is offline jaste  Sweden
Default Output resistors for parellell 4780
Is there any problem using 0.1 ohm 2w dale resistors as output resistors instead of 0.1 ohm 3w when driving the llm4780 in parallell config?
Old 17th January 2007, 01:08 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
It depends on much output power is needed.
Old 17th January 2007, 07:05 AM   #3
so how restricted am I if I use the 2w instead of the 3w?
Old 17th January 2007, 08:51 AM   #4
tlmadsen's Avatar
You should be fine under normal use.
Remember: P(W)=I*I*R
So in your case you can pull around 4,5 amp before it should get to hot.
H
Have fun
Thomas
Old 17th January 2007, 11:36 AM   #5
sixtek's Avatar
No-no, Tlmadsen you aren't right.
A 2W rated resistor will get to hot even at 0,5-0,7W. At 1-1,5W it will be very, very hot.
Old 17th January 2007, 11:54 AM   #6
AndrewT is online now AndrewT  Scotland
Default Output Emitter Resistors
how long will it take for them to get hot?
and very very hot?
How long will the current be at or exceed the value required to get the emitter resistors to either of these temperatures?
If the time constant of the signal is shorter than the time constant of the thermal capacity of the resistor then provided your are not running with maximum continuous ouput power nor a severely clipped output then the resistor will never get up to these temperatures.
What is needed is surviveability at the peak current output into low loads and reasonable running temperatures at normal to loud music level.
Keep in mind that each emitter resistor carries halfwave rms current when sending unclipped sinewave to the output. Power dissipation will be related to the half wave Isquared R loss.
regards Andrew T.
Old 17th January 2007, 01:30 PM   #7
alright, sp if I drive a pair of 4 ohms speakers and dont go too loud for too long then I should be ok with my 2w resistors?
Old 17th January 2007, 02:07 PM   #8
2w will easily cope with normal music reproducing operation.
But will they survive power testing or accidental shorting of output?
regards Andrew T.
CFP output emitter resistors ian_elvar Solid State 17 3rd March 2008 06:40 PM
Toroid output voltage for 4780 parallel? zdr Chip Amps 20 25th February 2008 07:33 PM
Aleph output resistors Stabist Pass Labs 5 3rd February 2005 04:33 AM
output resistors questions Svetlana Pass Labs 1 2nd July 2004 09:55 AM
Resistors in the output stage Solid Snake Solid State 42 18th January 2004 08:56 PM
Page generated in 0.15202 seconds (46.98% PHP - 53.02% MySQL) with 10 queries
