FINALLY; I have finished my stereo LM3886 board.
Old 16th January 2007, 09:48 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default FINALLY; I have finished my stereo LM3886 board.
Hi all,
I am very excited. Finally i finished and tested my amp last evening.
As you can see in the schematic, i added some (+7dB) gain on 20Hz-50Hz band. Its for eqalising to my speakers and calculated. I putted no zobel and no input decoupling cap. Also i dont use an input load, potentiometer acts as input load.
This is the PCB layout for stereo circuit;
Old 16th January 2007, 09:56 AM   #2
Dxvideo's Avatar
As you can see at the photo, its very crowded PCB but it works very stable.
I can hear no noise, no hum, no buzz or no switch on pop. In fact i didnot test it with real music and my spk.boxes. But as i tested with my signal injector and little midragnes (10cm) the amp works very clear.
The PSU was my 2x24v 4,5A SMPS and on board i use only 1000u+10u+100n as snubbers.
Old 16th January 2007, 10:00 AM   #3
Dxvideo's Avatar
I will test it with my iPod and speakers tonite. I will write the results tomorrow.
Special thanks to Mr.Nico RAS from here. He helped (still helping) a lot on that project.
Old 16th January 2007, 11:42 AM   #4
Dxvideo's Avatar
And a question as usual;
I want to put it a small box. Never mind the PSU, i will put it in another enclosure.
I have some worries about the heatsink dimensions that i have a huge one like this;
Its a 20cm x 10cm and i guess its about 0,7C/W. But i dont want to use it because of the dimensions. I will drive 4ohm speakers and use it for my iPod (50Wx2 max) in my room (not for parties) Under that situations; may i use a pair of socket 478 standard heatsink without fans?
Thanx a lot.
Old 16th January 2007, 11:48 AM   #5
Panelhead is offline Panelhead
Default Small value resistors
The actua; benefit of these is clear, why they help is debated. But try adding some less than one ohm resistors in series with those 100n caps. Connect the cap to ground and the resistor to the rails.
This will make what is known around here as a snubber. I know the theory of parasitic oscilations, but cannot see with my slow scope.
What I hear with these added resistors is a smoother, more even tone. Once I swapped them in and out a couple times it convinced me that just adding a small bypass cap is not always beneficial. But a small bypass and resistor has always been an improvement.
George
Cheapest is bestest
Old 16th January 2007, 11:55 AM   #6
Dxvideo's Avatar
Hmm interesting.
These under one ohm resistors will help to 100n's for snubbing? Its special for SMPS supplied applications or a general matter? And will these resistors have wattage (4W or more) ? Or 1/4W enough?
Old 16th January 2007, 03:38 PM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
Look for some plumber's flux at the hardware shop... it will make your solder flow nicer...
Old 16th January 2007, 05:36 PM   #8
Originally posted by Dxvideo
Hmm interesting.
The 1/4 watt will work. The purpose is dampening the small cap to prevent ringing. I have seen all kinds of graphs and pics showing the benefits.
All my beliefs come from listening. I can hear that it helps give smoother sound.
Try it as is, then add the resistors to see for yourself.
I think the lower wattage will be better for another reason than just availability. The lower wattage are smaller, so should have less inductance. And easier to shoehorn down there under the circuit board.
George
Cheapest is bestest
Old 16th January 2007, 05:44 PM   #9
CarlosT is offline CarlosT  United States
I found that some 1/2 watt resistors are too big (too long) to easily fit in the spacing provided in some kit PCBs. Funny enough, the Panasonic carbon film 1/2 watters are smaller than Xicon carbon film 1/4 watters of similar value...go figure
Kudos to Panasonic for making little resistors?
Old 17th January 2007, 08:04 AM   #10
Dxvideo's Avatar
Plumbers flux! Whats it? A kind of solder?I have never heard it before. In fact its very hard to make a solder path on PCB.
By the way; last night i tested my LM with my iPod and Sony spk boxes from my FH411. (I will do a real spk.box for it this weekend). The sound was very clear and free from distortion or noise. Bass level was very satisfactory because of the Linkwitz equalisation. But the problem was; total output level is about 10W each at full volume as i can mesure (or sense) with my EARS.
Do you think 27dB is not enough (on flat response)? Or iPods headphone output level is not high as needed? Or should i use a preamp, but i will use it for just my iPod and PC...
FINALLY; I have finished my stereo LM3886 board.Hide this!Advertise here!
Finally finished my amp! bikedude Chip Amps 16 18th June 2006 07:08 AM
Finally finished my first tube amp! Jeb-D. Tubes / Valves 34 1st June 2006 05:53 PM
I have finally finished my SUB! Fabiano Subwoofers 12 20th October 2003 01:39 AM
finally finished computer amp! Colt45 Tubes / Valves 10 24th June 2003 05:01 PM
Finished ESL picture (finally!) phishead8 Planars & Exotics 23 21st November 2002 08:55 AM
