| Chip Amps Amplifiers based on integrated circuits |
I just received some LM4780 boards this week. I downloaded a schematic and I am wondering if there is a mistake in the downloaded copy. It shows C6 as a 4.7 uf value and has provisions to install (2) 100uf caps in series. Should this be (2) 10uf caps in series? Actually would the value be critical at all since it is the Ci to ground?
The gain on the non-inverting side of the amplifier looks like it would be 10.7 and the gain on the inverting side looks like 11.7 Am I not seeing things clearly? |
#2 |
the gain on the non-inverting side is 1 + R1/R2 (it's just an opamp on steroids), the inverting side gain is just the ratio of the two resistors.
you have the option of lowering the f3 of the amplifier by using larger coupling caps -- fwiw I used 4.7 uF polypropylene in the AX article. |
| Another Single Side LM4780 Board.. | Dxvideo | Chip Amps | 12 | 9th February 2007 06:32 AM |
| LM4780 Eval Board | Wynand | Chip Amps | 0 | 9th December 2005 08:24 PM |
| My LM4780 Board | Kevin Haskins | Chip Amps | 32 | 14th February 2005 10:19 PM |
| Anagram Tech upsampling DAC board set | Ric Schultz | Swap Meet | 1 | 4th May 2002 04:13 AM |
| Page generated in 0.20389 seconds (21.13% PHP - 78.87% MySQL) with 10 queries |
