Old 12th January 2007, 05:11 PM   #1
Unhappy Problem with LM4780
Hello,
I have a problem,
I found circuit in this forum:
www.e-ideja.com/dielkius/schematic.gif
And I made PCB for that:
www.e-ideja.com/dielkius/pcb.jpg
www.e-ideja.com/dielkius/pcb2.jpg
And there is a part schematic:
www.e-ideja.com/dielkius/parts.jpg
I have 2 transformers, one 33-0-33 and one 15-0-15 (there is values after diode bridges). I connected +33 G -33 then I conected +15 -15 and that transformer ground connected with PCB ground.
And a problem: When I turn it on nothing happens, LM's get warm, but speaker silent, no buzzz or etc. Whats wrong? Maybe you can help me..
Old 12th January 2007, 05:40 PM   #2
Juergen Knoop's Avatar
probably impossible to tell you what went wrong.
It needs some troubleshooting with scope, signal generator and so on
at least there is one design error on the schematic...
a bias resistor at U4 is missing, you could try 47k from pin 3 to ground.
without a path for the bias current the operational amplifier could latch up. Maybe thats just your problem.
Old 12th January 2007, 06:09 PM   #3
btw. are the inputs of U5/U6 shorted?
why a second transformer?
Juergen
Old 12th January 2007, 08:32 PM   #4
Second transformer is for bufer and driver (OPA134 and DRV134) I don't use that part of schematic where is LM317 and LM337, I use another transformer to power up that two micro's.. Now i'm going to try put resistro 47k...
Thank you juergenk,
And sorry for my bad english
Old 12th January 2007, 08:32 PM   #5
Nop, 47k resistor not help...
Old 12th January 2007, 10:24 PM   #6
Default LM4780
Check your mute pins if the mute is alright bypass the ins on the 4780 inject the signal there without the buffer and DRV134
Old 13th January 2007, 09:14 AM   #7
Hi halo0925,
Thank you for reply, i tryed to put signal without bufer and driver, first to one LM and it worked, and then to another LM, and it worked too..
So problem is driver or bufer..yes?
Old 13th January 2007, 12:47 PM   #8
AndrewT is online now AndrewT  Scotland
I thought chipamps needed decoupling (electro + film/ceramic) right at the supply pins. Neither of these parallel pairs have any local decoupling.
regards Andrew T.
Old 13th January 2007, 01:06 PM   #9
I take another schematic without buffer, just driver (DRV134) and everything works OK..need another buffer, and new PCB
Problem with LM4780 Cyberzim Chip Amps 14 24th January 2010 05:40 PM
LM4780 problem - need Help AndriyOL Chip Amps 56 29th January 2009 07:58 PM
LM4780 problem Lamicz Chip Amps 6 6th November 2005 01:50 AM
LM4780 problem Faber Chip Amps 8 16th August 2004 04:39 PM
Page generated in 0.16979 seconds (57.42% PHP - 42.58% MySQL) with 10 queries
