Old 12th January 2007, 11:20 AM   #1
Default lm3886 psu
i am about to begin building a lm3886 amp, and wondered what transformer would be appropriate for my application.
i will be using this to drive 8 ohm paradigm atoms (89db), and would like to only use only one transformer to begin with to keep costs and complexity down.
dual secondary transformers seem to be rather hard to locate, so i would ideally like to use something that will work with just one of the avel transformers i can easily order from parts express.
i would very much appreciate any of your opinions/suggestions. thanks.
-oh, and also, i was planning on using a 50k pot for volume. is this an appropriate value?
Old 12th January 2007, 11:21 AM   #2
pinkmouse's Avatar
These questions have been answered many,many times before. Did you search before posting?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 12th January 2007, 11:58 AM   #3
yes, i have searched, but i cannot seem to find an answer to this. i cannot find anything that uses a single transformer without dual secondaries.
Old 12th January 2007, 12:14 PM   #4
Juergen Knoop's Avatar
I´ve always used a single transformer within my stereo LM3886 amps. Of course it has dual secondaries, witch are necessary for split or dual power supply.
With a single secondary you need a different 'single supply' circuit. So have to change the layout etc. I won´t recommend it until you are more experienced.
But there´s no problem at all.
Transformers with dual secondaries are standard and easy to find.
I wonder if things overseas are that different.
Juergen
Old 12th January 2007, 12:17 PM   #5
Nordic is offline Nordic  South Africa
Nordic's Avatar
And now the PSU hmm...
Old 12th January 2007, 01:23 PM   #6
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I am using an Avel Lindberg 330va 2x25vac transformer for powering my LM3886 amp. (stereo configuration).
Brian
Old 12th January 2007, 01:37 PM   #7
Nordic's Avatar
Are those nice...? got a 2 x 20V 15VAx2 one on the market the other day for like 2 dollars,might use it in my preamp, as I only have a 12v supply a.t.m.
Old 12th January 2007, 08:20 PM   #8
MikeW is offline MikeW  United States
MikeW's Avatar
This will work fine.
http://www.partsexpress.com/pe/showd...number=122-615
MikeW
Old 12th January 2007, 11:24 PM   #9
d to the g's Avatar
I really think this site is superb... except the search feature.
I've never seen such a poorly executed search function, especially when the I search for a specific term and it returns the first page of a 147 page thread. Really doesn't do me any good.
Old 13th January 2007, 06:13 AM   #10
BrianGT's Avatar
If you use the "Show results as posts" option in the Search Options section, it should help you find the relevant posts in long threads.
Brian
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 07:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 06:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 12:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.19758 seconds (48.67% PHP - 51.33% MySQL) with 10 queries
