| Chip Amps Amplifiers based on integrated circuits |
#11 |
35+35 is the "dual secondary" part of the product description.
This is too high for a LM3886. 35*1.414=49 volts while max supply voltage is 84 volts (+/- 42 VDC). It would most likely work and only let out the magic smoke very occasionally... it's just too high. The next question is the impedance of the speakers you MIGHT be using. You should start reading the data sheet. http://www.national.com/pf/LM/LM3886.html |
#12 | |
![]() /Hugo |
#13 |
Burnded fingers,
In a normal center tap 4 doides are used in the bridge +/-,-/+ and center "full wave". In a dual secondary 2 bridges are used and the centertap is taken by connecting the + from the top bridge to the - of the bottom" full wave*2" the result is less ripple, I guess you could call it artificial dual phase Snubbers have been around from the dawn of electronics, they help "snub out" unwanted frequency,s on the DC line, some frequency variations from the outputs collectors or emitters will make it onto the DC supply lines, snubbers RC networks help elliminate these. There primary use was in RF circuits to elliminate RF hash on the supply. |
#14 |
#15 | |
Some say the 0volt ground connection is quieter in the dual sec+DUAL rect version But I have not been able to measure any difference. The main difference is the extra voltage lost through the extra rectifier and the extra cost. And how did THAT WORD miss the dictionary? It always excludes my completely innocent use if it.
regards Andrew T. |
| Use a single secondary x-former as dual PSU? | pixworld | Chip Amps | 7 | 9th March 2009 12:32 PM |
| Interest Check: Plitron 300VA 18V Dual Secondary Standard Transformers | twitchie | Group Buys | 108 | 21st October 2007 07:14 PM |
| dual primary//dual secondary toroid | larryg | Chip Amps | 22 | 6th September 2006 09:24 PM |
| 2 transformers instead of "dual secondary" ? | neutron7 | Everything Else | 7 | 7th November 2005 04:33 PM |
| Page generated in 0.11184 seconds (65.51% PHP - 34.49% MySQL) with 10 queries |
