| Chip Amps Amplifiers based on integrated circuits |
#1 | |
http://www.divdev.fsnet.co.uk/repair2.htm
Does LM3886 fail in this way ? |
#2 |
The tech merely replaced one chipamp with another of comparable specifications. Since the pinouts were different, he had to do some re-wiring from the old pins to the new ones. The numbers should be read as:
Original 1 and 5 pins on the LM3886 were rewired to the 13 and 8 pins on the TDA, pin 2 on the LM3886 is Not Connected, pin 3 on the LM3886 is changed to pin 14 on the TDA, etc. Guitar amps usually have lots of distortion and are pretty heavily abused. This isn't good for solid state electronics. Also, if the manufacturer was using a tube for looks and not for any function, then this amp probably had lots of style and little substance. It probably used lower tolerance and lower quality components (and too small of a heatsink) to cut costs and that usually doesn't help reliability.
Listen to the music through the stereo, not the stereo through the music. |
| CD723 Hack, did someone download it? | Andypairo | Digital Source | 23 | 20th April 2010 10:38 PM |
| Amp Hack schematic questions | rafaelblock | Tubes / Valves | 12 | 13th March 2008 09:35 PM |
| K7200 0-30v 0-10a Hack:) | gev | Power Supplies | 0 | 14th June 2006 10:57 AM |
| Ac30 | aladin | Tubes / Valves | 21 | 11th June 2005 09:17 PM |
| Page generated in 0.09429 seconds (62.72% PHP - 37.28% MySQL) with 10 queries |
