Old 7th January 2007, 01:04 PM   #1
bluegti is offline bluegti  United States
Default Which transformer for 4 Ohm speakers?
I've read numerous times the 25V transformers are good for 8 Ohm speakers. I have a pair of definitive technology BP-10's (original model) that are 6 Ohm. I want my amp to be safe with 4 Ohms if needed (I'm using the chipamp.com LM38886 kit).
Here are options I'm considering from Parts Express and a guy on Ebay:
  • 160VA 18V+18V
  • 250VA 18V+18V
  • 200VA 20V+20V
  • 400VA 20V+20V
  • 160VA 22V+22V
  • 300VA 22V+22V
Which one would be most appropriate?
Can someone point me to a place where I can find out why in layman's terms? I know how to solder and follow directions but don't know anything about the science of why 25V is bad for 4 Ohm speakers.
Old 7th January 2007, 01:14 PM   #2
pinkmouse's Avatar
Default Re: Which transformer for 4 Ohm speakers?
Download the datasheet, and work your way though the design guide for voltage and heatsinking. It may look daunting, but it is broken down into fairly basic maths and is about as basic as you can get.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 7th January 2007, 01:35 PM   #3
phn is offline phn  Sweden
phn's Avatar
You also might want to look into PSU design. 2x22V might not be enough to give you +/-25. At least not if you want to be on the safe side.
Old 7th January 2007, 01:58 PM   #4
your chipamps will give a maximum safe output of about 60W.
This will be into 4ohms if you select the transformer for that duty.
You will get less power into 6ohm, but I guess still adequate.
The VA should be about 1.5times the total output power.
The 160VA 18-0-18Vac
or
200VA 20-0-20Vac would do for two channels.
regards Andrew T.
Old 7th January 2007, 02:09 PM   #5
phn's Avatar
Andrew is right. 18-0-18 is roughly +/-25V.
But if you want a regulated PSU you will need, I would say at least, +/-30V for +/-25V.
Old 8th January 2007, 01:37 AM   #6
Send a message via AIM to fitchmicah
but the plans at chipamp.com call for a power supply with two rectifiers.
if bluegti chooses a center tapped transformer like 18V-0-18V or 20V-0-20V, wouldn't there need to be two of them?
Old 8th January 2007, 01:49 AM   #7
phn's Avatar
He will need two secondaries, or four leads. For example 2x18VAC, which will give +/-25V, or +25-0(ground)--25.
Old 8th January 2007, 01:54 AM   #8
those are hard to find and expensive!
wouldn't it work to use two center tapped transformers in place of a single transformer with two secondaries?
I'm honestly thinking about just buying a T-Amp and building something else for my first DIY cause the power supply is going to be like twice as much as the amp, and I only have like $100 right now!
Old 8th January 2007, 07:24 AM   #9
a chipamp reduces the total cost of the amplifier.
You may find that the amp part is now only 5% of the total cost.
Many chipamp PCBs are designed to suit dual secondaries with dual rectifiers. As far as I know all can be modified to work with a centre tapped secondary and single rectifier. If you need support for the modification then come here or ask the designer.
regards Andrew T.
Old 8th January 2007, 11:51 AM   #10
Default centre-tapped transformer
Hi Micah,
You can find an example of the modification to use a
CT transformer in Brian's original LM3875 kit documentation:
http://www.audiosector.com/nigc_kit-users_guide.pdf
Section #3.1 contains a wiring diagram for a CT transformer.
Dennis
DIY Electrostatic speakers Audio Transformer??? pmscompany Planars & Exotics 49 22nd February 2009 03:28 PM
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
Transformer Hum leaks to Speakers kff322 Tubes / Valves 16 17th January 2007 11:01 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.21243 seconds (44.43% PHP - 55.57% MySQL) with 10 queries
