Old 7th January 2007, 07:55 AM   #1
netrino is offline netrino  Greece
Default chip amp with distortion pin (?)
Hi! i'm new here...
recently i've made this simple amplifier
http://www.nxp.com/acrobat/datashee...1557Q_CNV_2.pdf
somewhere in the PDF says that if we connect pin 12 (Vref) with two diodes to the ground then the distortion is reduced...
can someone tell me what kind of diodes do i need and how i connect them? (i have some BA159 spare...)
P.S i have already posted it on another topic but problably nobody reads it there because of the topic title...
Old 7th January 2007, 08:10 AM   #2
did you test your link?
It took me to NXP and said "page requested is not found".
regards Andrew T.
Old 7th January 2007, 04:50 PM   #3
i believe it's ok now...
http://www.nxp.com/acrobat/datasheet...557Q_CNV_2.pdf
check page 4
Old 7th January 2007, 05:24 PM   #4
the spec does not call up the diode voltage, so I guess they are not zeners.
Assuming they are standard signal diode then two in series gives about 1.4V. But, this does not look right, the single supply amps probably need half supply voltage on the input pins.
I note a reference to DC voltages of 6V and 6.9V but I don't understand those either.
It should be safe to try a pair of 1n4148 , until someone else jumps in with a tried/tested solution.
regards Andrew T.
Old 7th January 2007, 09:59 PM   #5
i have tried the BA159 in series and nothing happend.....
i tried them to the opposite direction and the power supply
started to shaking!
Old 8th January 2007, 07:51 PM   #6
Ηι...
nobody knows if it worths to do something with the pin 12?
and how am i going to do it?
Old 8th January 2007, 08:32 PM   #7
Netlist is offline Netlist  Belgium
Netlist's Avatar
But you didn’t measure harmonic distortion at low frequencies, did you?
I'd like to know as well, searched and found nothing but if the amp plays fine, who cares?
/Hugo
Old 8th January 2007, 09:55 PM   #8
/Hugo
no i haven't measured anything...but neither my ear heard any difference...as i said before it's a simple amp and it doesn't worth to
spend much time with it, i just want to tune it as much as i can and then leave it for future use...maybe for self powered speakers or something...
i appreciate any help with this mysterious pin 12!
Stand Alone Distortion Analyzer Chip Bonsai Solid State 5 14th February 2008 02:16 PM
Too much distortion lky Tubes / Valves 0 8th February 2008 02:11 PM
Lowest noise and distortion Chip Anders_denmark Chip Amps 15 16th June 2006 02:03 PM
Chip amp distortion with high impedance resistive load. Circlotron Chip Amps 3 26th January 2005 02:02 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
Page generated in 0.18108 seconds (45.91% PHP - 54.09% MySQL) with 10 queries
