Old 6th January 2007, 05:36 PM   #1
syber is offline syber  India
Default PCB layout for TDA1557Q
Hi all,
i'm new to this forum and i want to make a power amplifier with TDA1557Q.
Can anyone please provide me the layout.
please.javascript:smilie('')
frown
Old 6th January 2007, 07:06 PM   #2
netrino is offline netrino  Greece
Hi! i'm new here...
recently i've build the same amplifier Syber wants to build...
http://www.nxp.com/acrobat/datasheet...557Q_CNV_2.pdf
somewhere in the PDF says that if we connect pin 12 with two diodes to the ground then the distortion is reduced...
can someone tell me what kind of diodes do i need and how i connect them? (i have some BA159 spare...)
@Syber the TDA1557Q is very simple to construct it...you can even building in a bread board.
Old 15th November 2011, 01:09 AM   #3
formula 22's Avatar
Hello all!
And I seek PCB for this amplifier.
thanks
Old 16th November 2011, 02:50 PM   #4
kuldeepsingh's Avatar
Send a message via MSN to kuldeepsingh Send a message via Skype™ to kuldeepsingh
what friend. do u really need a PCB layout for TDA1557Q??
its the simplest amplifier chip available with zero component count. Simply solder the IC on a general purpose PCB and solder pin headers for input and output. put 2 caps for power supply filtering. And you got a working 4 ch amplifier
My Best LM3886 PCB layout
Old 13th December 2011, 04:45 PM   #5
yliroma is offline yliroma  Italy
Default H.W. mounting TDA-xxxx on Experimental PCB
How to solder such a Chip-Amp on the commercial experimental PCB's ?
The usual ones have a pace of 2.54 mm.
Chips have the front-pin's-line spaced 2.54mm ; the back-pin's-line is spaced 2.54mm as well but misaligned with respect to the Front one.
Any suggestion on "how to do" ?
Tda1557q mravlcax Chip Amps 6 7th May 2012 06:06 PM
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 9 9th July 2011 04:34 AM
Whose layout is this? Ulew Chip Amps 9 14th December 2008 02:33 PM
TDA1557Q start bum mravlcax Chip Amps 4 4th May 2007 12:44 PM
is my PSU layout OK? tinkerbell Solid State 26 31st March 2005 01:02 AM
Page generated in 0.11851 seconds (57.27% PHP - 42.73% MySQL) with 11 queries
