Yet another transformer question.... - diyAudio
Old 5th January 2007, 11:54 PM   #1
dbailey is offline dbailey  Canada
Default Yet another transformer question....
I have a Plitron toroid transformer with a 117 VAC primary and dual 25 VAC secondaries. The transformer is rated at 300 VA.
Tonight I connected the transformer to power and made some quick measurements. My input measured 122 VAC and my secondaries measured 27.4 VAC each.
I would like to use this transformer with one of Peter Daniel's LM3875 kits and a pair of Energy C-3 speakers which I believe are 8 ohms. Eventually I may migrate to a single driver speaker setup.
My question is this: is my transformer suitable for use with this CG kit and these speakers.
Thanks in advance for answering my question.
David
Old 6th January 2007, 10:29 PM   #2
elaar is offline elaar  United Kingdom
yes that transformer is fine. Remember you're measuring the transformer with no load, so with a 300VA transformer you probably have around a 7-10% regulation, hence your reading of 27.4. Your input measuring 122 (rather than 117) isn't a problem.
Anything over 35v (which is perfect for your 8ohm speakers by the way) will be dissipated as heat, so make sure you have a good heatsink(s)(read the LM3785 docs).
I don't know much about your speakers, but assuming they are 8 ohms and have no nasty characteristics, then your transformer and amp kit will cope just fine.
Hope this helps,
Andy
Transformer question? mcameron Parts 5 23rd January 2005 07:52 PM
transformer question xcortes Chip Amps 0 31st October 2004 05:04 AM
Transformer Question TunaFish Tubes / Valves 15 18th June 2004 11:20 PM
Transformer Question toque_101 Chip Amps 2 26th January 2004 05:21 AM
Copyright 1999-2017 diyAudio
