Old 5th January 2007, 04:13 PM   #1
impsick is offline impsick  United States
impsick's Avatar
Default psb sounds like hair clippers buzzing
ok so im having an issue. im using brians LM3886 boards. i have a 24v-0-24v ct transformer.
i read on a post of someone using a ct transformer and basically said send 24v(A) to AC1, 24v(B) to AC2, and the CT to both. so i did that and the psb seem to power up good. LED lite up, V-,PG- =34vdc, and V+,PG+=34vdc.
problem is once i hook up the amp board and power up the psb vibrates, basically sounds like hair clippers.
ha ha laugh it up. as long as you all find it amusing. jk,
i dont know what the deal is. V-psb to V-, V+psb to V+, &PG+- to corresponding pg's+-.
id appreciate the help if aanyone understood me
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 5th January 2007, 05:29 PM   #2
impsick's Avatar
anybody??? got any idea??
i was messing w/ it and i pulled v- and pg+ and turned the amp on and it didnt buz. is it possible i need to switch v- and pg+ destination? **** i dont know
Old 5th January 2007, 07:42 PM   #3
BrianDonegan's Avatar
From PD's 3875 document...
Twisted Pear Audio
Old 6th January 2007, 02:00 AM   #4
impsick's Avatar
brian would this apply to the lm3886 psboard too?
Old 8th January 2007, 02:27 PM   #5
CarlosT is offline CarlosT  United States
Originally posted by impsick
...is it possible i need to switch v- and pg+ destination? **** i dont know
I wouldn't think that's a good idea...both the diodes and capacitors are polarized on the rectifier board and further downstream on the amp board.
Old 9th January 2007, 11:27 PM   #6
pictures are definitely worth a thousand words when you are hoping for responses
Old 10th January 2007, 08:09 AM   #7
megajocke's Avatar
positive and negative rectifier + center tapped transformer = short circuit... Draw it up and you see that the diodes short the transformer during one of the half cycles. If you have a centertapped transformer, connect the center tap to the common after the rectifiers instead.
The picture Brian posted will work, connect it like that if that is the board you have.
About to pull my hair out! Working on ORION 2250 Samuel Rock Car Audio 9 24th December 2008 02:13 PM
jeemus! FE126E-P10 puts hair on chest! blumenco Full Range 69 13th December 2007 10:31 AM
Ingrown facial hair : the joys of shaving :( ash_dac The Lounge 19 14th June 2006 07:12 AM
Page generated in 0.12070 seconds (50.95% PHP - 49.05% MySQL) with 11 queries
