| Chip Amps Amplifiers based on integrated circuits |
#21 | |
![]() Since I built my first gainclone (several months back), I have wanted to build a tube preamp and to mate it with a solid state power amp, a gainclone. Not long ago, I was able to finish a gainclone with unity gain (Thanks, Kuei). Why unity gain? It's because I'm thinking to let the tube preamp do all the voltage amplification and power amp will be supplying simply power to the speakers. These days, I'm looking for a tube preamp which is SIMPLE because I'm totally new to tubes. The one in your link looks pretty simple and could be my next project. |
#22 |
Previously: Kuei Yang Wang
I thought it would be obvious that you can use ANY kind of preamp you like. Woul I recommend the 6072A Preamp for use with a solid state Buffer? Probably not. It's sonic charater would be better complemented by a 300B SE Amp. Hence my suggestion of the 5687 (or indeed 6H30) as Valve for the "preamp" stage (please DO NOT try to use the ECC88/6922 types). The 5687 has a powerfull, warm and pleasant tone. The Arthur Loesch preamp is widely published on the net, including here: http://joelist.free.fr/schematics/ph...%20Loetsch.gif other more or less similar options with 1/2 5687 per channel are here: http://joelist.free.fr/schematics/5687pre.jpg The Audio Note Japan M7 Line Stage also used the 5687 as shown here: AN M-7 and M-100 Materials BTW, the suggested non-zero output impedance is part and parcel of the suggeted "soundalike" Amplifier... Sayonara |
#23 | |
Why oh why? Because of the high Rp ? Or are there some other (sonical ???) reasons?Can I find any use for the 6N1P-s I have laying around at all? argo |
#24 | |
The 5687 has a very different tone, as has the 6H30. The 6H1P you mention has little to do with the ECC88/6922 Family BTW, both design/performance/sonic wise. Still, I'd not use that one either. I'm sure you can find decorative uses for the ones you have. Sayonara |
#25 | |
Perhaps like for ?Hoo- hoo |
| Wikipedia Article on "Tube Sound" | sardonx | Everything Else | 2 | 8th November 2007 02:20 PM |
| "Old Like" sound transformer with a Tube ! | -_nando-_ | Tubes / Valves | 3 | 30th October 2006 11:27 PM |
| Simplified LM3886 amp pcb "organic" style | Groundloops | Chip Amps | 0 | 23rd May 2006 03:46 PM |
| Is it possible to get "tube sound" with just a tube preamp and chipamp output? | Spasticteapot | Instruments and Amps | 43 | 15th May 2006 06:28 PM |
| Hey, I'm looking for some of that "tube sound"! | Saurav | Tubes / Valves | 22 | 20th July 2003 12:10 AM |
| Page generated in 0.10300 seconds (77.06% PHP - 22.94% MySQL) with 10 queries |
