Old 4th January 2007, 03:31 PM   #1
spwal is offline spwal  United States
Send a message via AIM to spwal Send a message via Yahoo to spwal
Default Do chipamps have clipping danger like SS amps?
I will be running a 25 wpc chipamp from a patek se kit and am concerned that power may be too low to run my 99Db 8 ohm speakers. The speakers are very nice and i do not want to damage them. As i understand it, they can be damaged if underpowered, even at very low volumes.
please forgive my noobness.
woo hoo!
Old 4th January 2007, 03:57 PM   #2
pinkmouse's Avatar
Yes, chip amps do clip. But with 25W and 99dB efficient speakers they will be pretty loud when they do so. But if you are still worried, you could always change the feedback resistor to reduce gain.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 4th January 2007, 05:20 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
Here you can see how see how the clipping look like (my "Gainclone" built by Keld).
http://www.keld.eu/gainclone/test.htm
Notice the 100% clean startup and shutdown behaviour (the first pictures).
/Per-Anders (my first name) or P-A as my friends call me
Old 4th January 2007, 05:23 PM   #4
thank you for the replies.
was concerned with causing dangerous distortion on strong transients. i was under the impression that this could occur regardless of the volume.
I dont ever plan on cranking these speakers to rediculously loud levels.
please tell me if this is something to concern myself with.
thanks
woo hoo!
Old 4th January 2007, 05:32 PM   #5
peranders's Avatar
Can you explain that?
Transients are signals with a certain frequency spectrum. If you have a CD as a source frequencies higher than 22 kHz won't ever come out of the CD player (if the filtering is good).
Old 4th January 2007, 05:43 PM   #6
hi,
i guess what i ment to say was sudden bursts of complex music, i guess it doesnt matter as long as the amp isnt turned up that loud and pushed beyond its limits. thank you for your help
woo hoo!
Old 4th January 2007, 06:08 PM   #7
Steve Eddy's Avatar
Heheh. That's pretty cool plotting the + and - supply rails along with the output like that.
se
Old 4th January 2007, 06:40 PM   #8
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: Do chipamps have clipping danger like SS amps?
I was using $800/pc FAL drivers with bridged Patek amp for some time. The drivers impedance was 4 ohm, so each amp was working with 2 ohm impedance. At normal levels it was fine, but at higher volume, on material with substantial bass content, the clipping was unavoidable and quite severe. However neither the amp, nor drivers have been damaged.
Presently, with 100db, 8 ohm Fertins, there is no clipping at all. This is still 4 ohm load per amp, so you should be safe with your speakers.
Anybody tried FAL drivers?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 4th January 2007, 07:26 PM   #9
There is no one i would like to hear this from more than the man himself. thanks peter!
woo hoo!
Old 4th January 2007, 08:04 PM   #10
lineup is offline lineup  Sweden
lineup's Avatar
different chips has got different Overload protection.
The national overture series LM3875 LM3886 and LM4780
has got SPiKe protection
This means that at very high currents PEAKs will be blocked.
The level at which this protection limits, is a bit different for different chips.
I do not know if LM1875 has got this, too.
But this is for a bit lower power output than the others.
LM3886 / LM4780 allows more current output than LM3875, before this limit comes into action.
This makes LM3886 better suited for 4 Ohm speakers at higher powers.
The performance of the LM3886, utilizing its
Self Peak Instantaneous Temperature (°Ke) (SPiKe™) protection circuitry,
puts it in a class above discrete and hybrid amplifiers
by providing an inherently, dynamically protected Safe Operating Area (SOA).
SPiKe protection means that these
parts are completely safeguarded at the output
against
- overvoltage,
- undervoltage,
- overloads,
- including shorts to the supplies,
- thermal runaway, and
- instantaneous temperature peaks.
For further information, I would recommend:
Read about the SPiKe details in datasheet of LM3886:
http://www.national.com/ds.cgi/LM/LM3886.pdf
New Year 2007
lineup
http://lineup.awardspace.com/
lineup
Chip amps and clipping/protection behavior danielwritesbac Chip Amps 4 28th March 2008 04:58 AM
Car Audio Danger Timn8ter Subwoofers 1 1st August 2007 01:10 PM
Is my amp in danger? mudihan Solid State 12 17th July 2006 06:00 PM
USA In Grave Danger!!!!! mikeks The Lounge 68 13th September 2004 05:22 PM
Gainclone and clipping (may also be appliable to other high feedback amps) Bricolo Chip Amps 8 26th November 2003 01:46 PM
Page generated in 0.17782 seconds (55.91% PHP - 44.09% MySQL) with 10 queries
