Old 2nd January 2007, 11:50 PM   #1
Default LM3886 Plans, any mistakes?
Hey everyone,
I am planning on using a dual mono LM3886 amp kit from www.chipamp.com with an AVEL 330VA 25V + 25V transformer from partsexpress. I'm new to this so I was hoping people could give me some advice, or point out any mistakes I've made so far.
I will most likely be driving a pair of Axiom M22 speakers which are 8 ohm, so I'm guessing the +/-35V rails will be ok. Each chip will have a 3.2" X 2.4" X 1.8" (L X W X H) aluminum heatsink.
I'm still not sure what kind of pot I want to use. Can anyone recommend one that's easily available in the US, has decent tracking between channels, and sounds good? (up to $30). Also, is 25k a decent value, or should I go lower/higher?
Also, should I keep the speaker and input grounds isolated from the chassis ground and each other like in the picture?
Old 3rd January 2007, 06:08 AM   #2
ianpengelly's Avatar
Hi there!
Your layout is identical to mine, so it should work fine, though as others will tell you there is sometimes an issue with hum due to the ground loop between the two amp boards.
I would go for a 50k pot, try an ALPS Blue, that should fit in your budget.
Hope this helps.
Old 4th January 2007, 08:12 PM   #3
Thanks for the quick reply. I've been searching for the alps blue (RK27112), and no place seems to have this particular pot. You would think this would be more attainable in the US with the popularity among the DIY community. Is tangentsoft.net reliable to order from?
Old 4th January 2007, 08:18 PM   #4
mr.duck is offline mr.duck  United Kingdom
Yea they are a pain to track down. tangentsoft.net is reliable. Also try ebay.
Old 4th January 2007, 08:21 PM   #5
Only 3 left in mouser... click here
I remember a topic about the fake alps pots on ebay, beware!
Old 4th January 2007, 09:04 PM   #6
Don't know what they are like in the US, but I have just ordered a Alps Blue from RS Components and they had plenty in stock.
Good luck getting hold of one!
Old 4th January 2007, 11:23 PM   #7
Is there a big difference in sound quality between the 50k and 100k?
Old 4th January 2007, 11:54 PM   #8
lineup is offline lineup  Sweden
lineup's Avatar
the good thing is you have drawn a nice overview
instead of simply connect anything just as it come
this will make it more easy for someone to give advice
if you get any 'hum' or 'ground loop' effects later
Better to have a plan before wiring
Wiring, as well as how PCB rails are designed,
are important things in amplifiers!
for correct working
Of course you will use isolated RCA, Left-right output jacks
this will make sure Chassis is only connected to Ground, 0V
at one single point
this is a way to avoid so called 'ground looping'
like you have done should work good
lineup
lineup
Cyrus 3 Amplifier Component Mistakes? hexagonsun Solid State 10 1st December 2009 07:34 PM
First build - Common mistakes Hugo82 Multi-Way 23 17th March 2009 09:16 PM
Can someone check My PCB layout against the Schematic for mistakes please?? Minion Solid State 9 6th June 2007 03:26 PM
PCB Mistakes/Optimization(?) OmarAvelar Chip Amps 19 10th April 2007 11:01 AM
toner transfer method(my mistakes) rs1026 Everything Else 3 13th October 2004 01:37 AM
Page generated in 0.14990 seconds (54.53% PHP - 45.47% MySQL) with 11 queries
