On & Off Thump - diyAudio
Old 29th December 2006, 02:07 PM   #1
Kinger is offline Kinger  United Kingdom
Question On & Off Thump
My Marshall MG15CDR makes a LOUD thump when switched on and when switched off - is this normal for this amp? - I also have a Fender amp of the same power rating, this only makes a gentle thump.
Perhaps some of you other users can enlighten me.
Thank you.
Old 29th December 2006, 06:56 PM   #2
Nico Ras's Avatar
You will find there is a substantial off-set voltage on the output at switch on and takes a while to stabilise. Does this bother you or was this purely out of interest.
The second posibility is that the amp is driven from a single supply rail and uses an output capacitor connecting to the speakers.
At switch on the output swings to half rail and the capacitor charges through the speaker and could be responsible for a big thump.
One way of checking is turn the amp on and off and on. If the thump is not that servere at the second switch on then this is most likely a single supply rail.
Old 31st December 2006, 11:46 AM   #3
Thanks for the reply, the amp has a symmetrical +/- 20V supply without a series capacitor to the speaker, the thump appears to originate from further down the line somewhere in the audio processing before the power stage. The output swings between the supply rails for up to 200mS after switch off. It is therefore at max volume - I just wondered if this is a feature of this amp, or is there a fault? - I wondered if anyone else out there had a similar amp and could report whether their amp makes a similar noise.
turn off thump jayme Tubes / Valves 26 10th December 2015 02:50 PM
What is that thump,thump,thump? 65blkbkgt Car Audio 7 17th June 2007 01:35 AM
aikido thump jayme Tubes / Valves 16 29th October 2006 10:17 PM
Anti-thump suzyj Solid State 15 21st October 2006 01:03 PM
Zen amp turn-on thump. vdi_nenna Pass Labs 2 22nd October 2000 07:27 PM
Copyright 1999-2017 diyAudio
