My Version of Mauro Penasa's LM3886
Old 30th December 2006, 12:12 PM   #21
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
[i]
I use parallel series 0.47R because I haven't found non-wirewound power resistor.
Thanks for help [/B]
I don't understand the need for .23 ohms in series with the speaker, what does it do?
Besides wirewound resistors are not inductive, if this was a concern.
Old 30th December 2006, 02:05 PM   #22
Russ White is offline Russ White  United States
Russ White's Avatar
It is actually there to sense current for feedback.
Please read this Nico: http://www.diyaudio.com/forums/showt...645#post702645
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 30th December 2006, 02:36 PM   #23
.....Besides wirewound resistors are not inductive......
wire-wound resistors can be made two ways.
inductive or less inductive.
The way they are wound determines into which category they fall.
The easy, cheap way is to wind a coil on a former and weld on the lead out wires. This is inductive.
The alternative methods involve winding coils that oppose each other to cancel the magnetic field. This cancellation will never be perfect but a substantial reduction in inductance can be achieved. Anything better than 90% reduction will cost more than the inductive wound type.
BTW,
1uH has a reactance of 0.13ohms @ 20kHz.
Imagine (or calculate/simulate) what effect this might have on emitter resistor feedback when the Re is of similar resistive value.
What happens when the frequency of interest is one or two decades higher?
Even 1nH starts to become significant cf 0r22.
regards Andrew T.
Old 30th December 2006, 03:26 PM   #24
Nico Ras's Avatar
Dear Russ,
very interesting reading thank you.
Kind regards
Nico
Old 30th December 2006, 03:28 PM   #25
Russ White's Avatar
Dear Russ,
Kind regards
Nico
You are most welcome, its not exactly easy to find. It is very good read though. I have actually done several Howland pump type amps, one using discrete components(not chipamp).
Audio
Old 30th December 2006, 11:52 PM   #26
Stanley Drake is offline Stanley Drake
Send a message via ICQ to Stanley Drake
I have soldered and assembled amplifier but it doesn't work
I think that this is due to SMD (very difficult to solder accurate) or burned LM3886.
I don't know what to do with this. I'm so tired from LM3886 (I already have made 2 amplifiers that work ok) but 3rd was unlucky one.
Maybe I should forget about that chipamp and try to make a discrete amplifier. What do you think about this?
Old 31st December 2006, 12:27 AM   #27
Russ White's Avatar
Or you could use a PCB that is tried and true. I posted a single side PCB PDF file on the MyRef thread.
Audio
Old 31st December 2006, 01:31 AM   #28
Thanks for advice but I think it's time for something more complicated
My fault that I used SMD. I will never use SMD again in amplifiers I'm unable to produce a good looking PCB with SMT
Old 31st December 2006, 01:41 AM   #29
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Stanley, by all means build another amp, but don't give up on yours. Learning to troubleshoot things like this is an invaluable skill, and can even be quite fun, (in a month or so, once the frustration has gone).
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
My Version of Mauro Penasa's LM3886Hide this!Advertise here!
X-Calibre : Hot Rodding Mauro Penasa's LM3886 design rudi Chip Amps 171 19th January 2013 10:38 PM
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 18th October 2010 12:42 AM
WTB: Mauro Penasa Ref C marginwalker Swap Meet 0 13th October 2007 06:28 PM
Mauro Penasa's INV GC/REF GC group buy. Russ White Group Buys 277 27th March 2006 09:57 AM
Copyright ©1999-2017 diyAudio
