| Chip Amps Amplifiers based on integrated circuits |
Hi there,
I built a chipamp from BriantGT and everything was in good working order. However, i have connected it to my new rogue preamp, which is said to be 'inverting' and now the amp is (I think) oscillating. I am not sure I have inverted the inputs from the pre to the amp, but if i didn't would it cause this behaviour? The other thing that i changed was to put the jumpers back onto my speakers to remove the bi-wiring... Thanks, Mantisory |
#2 |
What makes you think the amp is oscillating? Are you hearing hum or other noise? Is the chip getting hot even with no signal applied to the input?
I_F |
#3 |
do you mean you are not sure if input wires are the wrong way around? yes, this would cause some noise...
#4 |
the chip is not overheating - i checked that early on.
there is audible periodic (1 second frequency maybe?) noise coming from the speakers even with no signal. |
#5 |
1 second? Hhhhmmm...sounds like a long interval for the usual 60Hz stuff from the power side.
I got a terrible loud buzzing sound (prolly like 60 Hz) when I grounded the metal mounting tab on an LM3875T the other night. Could something be grounded that shouldn't? |
#6 |
yeah, maybe, i dunno - i am going to try some different speaker cables and also switch the inputs around.
it may be as wmuch as 2hz, but no more than that i think...i remeber that i had a similar problem in one channel when it wasn't connected to my speaker (I have read elsewhere that the chipamp doesn't like to be un-loaded), so i wonder if maybe my cabling is an issue.. |
#7 |
Disconnect your pre amp and short the input to the chip amp to ground and see if you get the same result, if you do its the chip amp if not its probably the pre or a cableing issue
#8 |
will give 'er a go after work - thanks.
| please help with an oscillating amp | ballai.tibi | Solid State | 101 | 19th June 2010 09:19 AM |
| Self oscillating fun | Eva | Class D | 92 | 17th November 2008 06:21 PM |
| Impressions of Snubbered BrianGT 3886 vs Reg 3886 | moving_electron | Chip Amps | 1 | 23rd March 2005 06:51 AM |
| oscillating...always oscillating | WoulYaShassu | Solid State | 30 | 9th April 2004 05:31 PM |
| Page generated in 0.16028 seconds (47.41% PHP - 52.59% MySQL) with 10 queries |
