Old 22nd December 2006, 07:41 PM   #1
pat allen's Avatar
Default Parrallel/bridged LM4780 ??
Hi, i am browsing the chip amp solution and am looking at all possibilities...
TDA72xxx,...
I made some extensive search and didnt find what i was looking for...
So i came to LM4780, 2 channel in parralel and two of theses in bridged...
anyone ever did this ?? that could make a very cheap and very powerfull amp...
anyone?
Electronic engineer for automotive market.
Old 23rd December 2006, 03:34 PM   #2
pat allen's Avatar
nevermind plz, i found later the BPA200...
thanks.
Old 24th December 2006, 05:28 PM   #3
Default Parallel fyi
I just built my daughter a guitar amp using Audiosector's 4780 kit and paralleled it. It has a tube preamp and drives 2 Eminence 12" speakers. It is very powerful! Great kit btw
Old 27th December 2006, 06:57 PM   #4
lgreen is offline lgreen  United States
lgreen's Avatar
Default I've built one
I've built one with no problems. Note that these need good heat sinking. Link to LM4780 Amp.
My DIY audio projects- PartTimeProjects.com.
Old 27th December 2006, 08:36 PM   #5
pat allen's Avatar
wow, thaks guys for the comments...
do you have any pictures ?
what did you used to compensate the dc output, servo, adjustable bias,...
I have all these big toroidal transfos, caps and huge heat sinks...not to mention that big mofo penultimate zen that i build and that i dont use at all ...i could swap in a lot of these LM4780
thanks guys.
Old 28th December 2006, 04:00 AM   #6
sangram is offline sangram  India
I did exactly what you said in your first post. I got two LM4780 kits from Audiosector, and set them up in the parallel mode on each chip. Then two boards are bridged (I have a soundcard with balanced output). I don't compensate for DC and there is no input cap. DC offset is 2mV on one channel and 6mV on the other. Have to really be confident of the fact that there is no DC on the input, else it'll cook the speakers...
It's reasonably cheap, very powerful (I estimate around 200 watts/channel) and not too bad-sounding either. The transformers are 440 VA EIs for each channel (this part of the world is still in the EI era), and I added 4700 uF per rail to the Audiosector kit's 1500uF. I had 10,000uF in there earlier, but I prefer it with less capacitance.
Bridged LM4780 Amp jackinnj Chip Amps 17 24th March 2011 04:36 AM
Lm4780 Bridged PCB Baracus Chip Amps 8 7th January 2006 12:45 AM
Bridged lm4780 rs1026 Chip Amps 2 12th September 2004 10:49 AM
Has anybody done a pcb layout for a bridged /parrallel gainclone mwmkravchenko Chip Amps 13 23rd August 2003 08:18 PM
Page generated in 0.13929 seconds (55.74% PHP - 44.26% MySQL) with 10 queries
