Old 22nd November 2007, 04:08 PM   #51
Puffin is offline Puffin  United Kingdom
ianpengelly. I have just built one of the Chipamp kits. Running on one PS at the moment (but I built two for pure dual mono) I have ordered another tranny, but are intrigued as to how you ran both boards off what appears to be a dual secondary tranny. Did you just daisy-chain the secondary's from one board to the other?
Old 8th December 2007, 09:57 PM   #52
ianpengelly's Avatar
Hi Puffin,
I just split each of the secondaries to wire up two PS boards, but like I said in my commentary it wasn't ideal because of the hum.
Andrew,
Nice work, a video would have been interesting to show what happened... I am slightly concerned that your fuse holder took off across the room! :-)
Old 8th December 2007, 10:00 PM   #53
Talking Update
I got round to replacing the front on my chipamp and my preamp, as they didn't really fit in with the rest of my gear with the silver fronts and also I had used pencil to indicate what the knobs were for on my pre-amp... classy eh?
Anyway, I decided to borrow an idea I had seen used for some speaker lables by someone on this site and use two sheets of perspex with a printed lable sandwiched between them to give the results I was after and here they are!
Old 8th December 2007, 10:03 PM   #54
And with slightly less reflection!
Old 9th December 2007, 09:01 AM   #55
Can we see some pics of the inside of your pre-amp and how you propose to go active with it ?
As you may remember I built a dual mono BrianGT amp. I have since made a P2P 3886 using Nuuk's excellent site (and his help on here !). Even made my own snubberised PS. Trouble now is I have two great sounding amps ( I used to have Audiolab per/power), but the one I slaved over for hours is the one that is running now !
I am using a valve pre, which semms to suit it very well. It has a lot of gain.
Old 9th December 2007, 11:31 AM   #56
I'll try and get some photos next time i have it open to wire up the later three inputs, as only the CD, Tuner and TV are wired in a the moment.
I am planning on building a buffer based around the OPA627 to make it active, with a regulated PS. There are a few designs out but this is the one I am most likely to follow:
http://www.platenspeler.com/diy/prea...chooser_3.html
If you have two amps, why not bi-amp? Or go surround sound, or use one with your PC as a second system? Lots of possibilities.
Is your valve pre one you built or bought?
Old 9th December 2007, 01:59 PM   #57
Thnks for that I have printed the details off and will read them later. I bought my Ming Da pre from Icon Audio. Excellent sound and value.
Death of Gain Clone widowmaker Solid State 341 12th April 2010 09:14 AM
pre amp for gain clone as guitar amp engel dela pena Chip Amps 13 24th July 2009 02:46 AM
FS: Gain clone and heatsinks vsr123 Swap Meet 12 14th February 2005 03:01 AM
CD player for Gain Clone falcott Digital Source 5 26th September 2004 06:04 AM
What is a Gain Clone exactly? Lars Clausen Chip Amps 33 26th November 2003 05:33 PM
Page generated in 0.16079 seconds (41.97% PHP - 58.03% MySQL) with 11 queries
