Old 21st December 2006, 08:20 PM   #1
geaugafletcher's Avatar
Default A quick (haha, no really) grounding question
Hello all, I'm assembling an LM4780 kit from Audiosector - but using half the kit. In other words, it's a stereo amp with one LM4780 chip. My question is this:
Is there any reason not to set the grounding up like this:
http://tinyurl.com/yfx28a
I'm grateful for any feedback or discussion.
For information's sake, three inputs will go to a rotory selector switch - the 'winner' passes the signal on two a DPDT toggle that'll switch between main amp and headphone amp. From there, the main amp signal goes to a volume pot, then to the amp. The headphone signal has the same sort of setup.
This is a lot of wire for the input signal to travel, I know, but it's the best I could come up with. All input signal will travel through shielded wire scavenged from Radio Shack shielded audio cables. Again, any advice or discussion is very welcome.
Old 22nd December 2006, 11:49 AM   #2
CarlosT is offline CarlosT  United States
I'm sorry but your picture shows two LM4780s?
Old 22nd December 2006, 02:53 PM   #3
Yes, I know. That picture isn't of the amplifier on my bench right now, but shows the same grounding scheme I'd like to employ. I'm asking a slightly general question about wiring up Audiosector LM4780 boards.
The signal and ground/common wire travel together from input jacks to selector switch to amp/headphone amp toggle to pot to amp to binding posts. It'd be an unbroken line, no star grounding.
Similarly, the Audiosector PS and amp boards are tied together as shown with just one ground wire tied to the chassis.
Does that clarify my questions?
OPT grounding question Nihilist Tubes / Valves 16 2nd June 2009 02:06 AM
quick grounding question gain Power Supplies 7 22nd October 2008 03:19 PM
Quick question about star grounding jn2630 Tubes / Valves 8 21st January 2008 01:31 AM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
grounding question skyraider Chip Amps 1 9th March 2004 09:12 AM
Page generated in 0.10036 seconds (58.72% PHP - 41.28% MySQL) with 10 queries
