| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I have worked on a stereo LM3886 GC project for a while. After my LM1876 (on test board) fiasco i decided to design a good PCB for my LM3886s... I seperated signal gnd (on right side) and power gnd (on left side). I kindly request you to say something about my PCB design.. - Does it work? - Is star signal gorund point (on AF clamp, pin 2) ok? Or should i make gorund plate on all right side? - Is C6 on NFB line necessary? Or may i ommit, so connect R3 directly to gnd? Is there anything i made mistaken? Or have you got some advices to add or modify? ![]() Thanks a lot for your helps in advance. With my best regards, Özgür. PS: I use one power supply for all. And will put a stereo 10K potentiometer before amplifiers. All system includes only these.. |
#2 |
For what it's worth, the layout looks quite similar to how I laid mine out (only yours is so much neater / looks so much nicer!)
I was worried about oscillation, but I am convinced now, after sticking a > 100nf cap across the output and seeing what I believe was full blown oscillation, that it's not. It seems to work rather well indeed. EDIT: I don't think C6 is strictly necessary, it'll virtually get rid of any DC offset. I didn't make room on my PCB for this capacitor, and had to bodge them on. I couldn't tell the difference in sound quality, but YMMV. I'd probably keep the space there, and if you don't want it stick a jumper bar / wire in there instead. EDIT: I'm not sure about the ground plane/plate surrounding the signal stuff. I've 'cleaned up' my board a bit for if / when I build another, and I now have the power ground covering the whole board. I haven't tried it, so I have no idea what kind of effects it'll have. My thinking was that any inteference would be more likely to choose to enter the big ground plane surrounding the signal stuff, so it would be better? It'll definately be easier on the etchant though ![]() Also not sure about the squiggly spkr/power to signal ground on mine. I wanted to see if I could have them all connected and not have hum. If it doesn't work, it's dead easy for me to just cut the traces and return the signals back individually ![]() |
#3 |
You mean you applied that design and have no noise or oscillation. Is it? And on your PCB you havent got seperated gnds so it is not necessary.. But i can see a long line (like UHF antenna) between power and signal gnds.. Why is it there?
By the way i am developing my PCB and will put 470nF and 2,2ohm in parallel between signal and power gnds, as recommended by Nico Ras Thank you friend. |
#4 |
#5 | |||
It's a long squiggly line because I figured a long thinner trace would mean more resistance. It might be a bad idea (probably is, I dont know anything about PCB layout), the shape of it might pick up interference etc etc etc. I don't really know, but again... it's easy enough to just cut the trace if there's humming / buzzing ![]() Quote:
I think you should change C6 back to at least 47uF. 22uF and 1k would be -3dB at ~7Hz I think, and from what I remember AndrewT was telling me, this would mean phase distortion (I think) all the way up to about 70Hz. |
#6 |
Yea Andrew said me the same but for another reason; to have about 1,5-2Hz lower cutoff frequency.. If i use 100µF or so i can get 1,6Hz (-3dB) cutoff with 4,7µF/27K input RC.. Then will turn to my old design with 100µF
Thanks a lot guy. |
#7 |
Yeah
100uF would be better if you can fit one there. I'd have to use 1,000uF to achieve the same as my resistor values are 10x lower, and 1000uF is kinda hard to fit in the space I had left, so I had to settle for 470uF (would be 47uF for you). I'm getting along just fine with it ![]() Let us know how you get on with it! I like mine, the sound quality is quite impressive for how small the chips are and how easy they are to build! I can't quite explain the difference. With one speaker on the old amp and the other on the new amp, fading between the two (very unscientific I know), I really can't tell the difference (though even simple sinewaves do look slightly different on the scope). But with both speakers on the GC... it's just like there's a whole new depth to the music. Might be imagining it, might be real. I don't know if I want to build a speaker switching (ABX?) test box to find out. I'm happy
#8 |
i designed this pcb layout in autocad and got it etched also, i tried to include star grounding. any comments please
#9 |
I guess i cannot use that PCB.. Because Nico Ras gave me another idea on three LM3886s. Its a 2+1 as i tried with 2xLM1876s in the past. But it includes no low pass filter before amp. It boosts under 100Hz on power stage.. It looks like interesting and will apply it with some modifications.
| Page generated in 0.14320 seconds (67.91% PHP - 32.09% MySQL) with 10 queries |
