Which toroidal is ok for the LM3886 and speakers 4 ohm?
Old 3rd January 2007, 01:06 PM   #31
CarlosT is offline CarlosT  United States
The idea was to create a cabinet that resembled an old Fender Champ tweed guitar amp that kids could plug in their iPod into and play music. This was an old school look and sound with one driver, no tweeter or crossover, etc. Going stereo would complicate the cabinet build and dimensions and would take away from the "old school" look.
I initially bought the AudioSector LM3875 kit but this is a non-inverting design so supposedly not well suited to combining channels. The inverting design lends itself better to combining channels. If you look at the picture of the "test mule", you can see that I'm cramming everything into a 9" x 5" x 2" Hammond aluminum box so no room for buffer preamp or regulators or any other fancy schmancy stuff. As it is, I got an Avel Lindberg 90VA tranny, an AudioSector rectifier board and a TechDIY amp board and a heat sink all in the little box
I'll post pics soon of the completed project.
Old 3rd January 2007, 07:50 PM   #32
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Hi Carlos,
what a grand idea. Maybe you could try an old table radio look as well and use the lit up dial for the volume control.
I am most impressed, hope this takes off well.
Old 3rd January 2007, 10:36 PM   #33
We have already successfuly delivered 2 "TweedybirdOnes" for Xmas...kids love them so far
Old 9th January 2007, 06:58 PM   #34
fosforo is offline fosforo  Italy
Maybe it could be a stupid question but should it be fine to use 2 x 100VA - 18VAC instead of 1 200VA 18-0-18 Vac?
Old 9th January 2007, 10:18 PM   #35
Dennis Hui is online now Dennis Hui  Canada
Yes...that should be fine. The larger transformer likely has
better regulation, but nothing to worry about.
Dennis
Old 10th January 2007, 05:52 AM   #36
ren@darkertek is offline ren@darkertek  United States
20+20 vac transformer
= 40 vac * 1.414
= 56.56 vdc / 2 for center tapped psu output
= 28.28 vdc rectified per rail - 0.8v diode drop
= 27.5 vdc per rail
gainclones at peak output in normal configurations are like 50% effecient...
(find the graph in the data)
so 63w * 2 = 126w, plus headroom cuz reality is mean.
so like, a 200VA 20+20vac transformer would be perfect
(i just bought two 400VA toroids to run pairs of 3886 amps =)
Old 10th January 2007, 12:05 PM   #37
Dennis
Yes, sure, but if the total power is calculated by a sum of each power from each seconday then, a transformer with a 18-0-18 200VA isn't the same as two transformer 18VAC - 100 VA?
Obviously we are just cosidering a theoric power calculation
Old 10th January 2007, 04:05 PM   #38
if you parallel the 18+18vac 100va secondary coils on one transformer, you have a single 18vac 100va part. each 18vac half of the secondary coils is actually 50va.
do this to the secondaries of both 100va transformers, put the parallel coils of each transformer in series, creating a center tapped part.
now you have 100va at 18vac + 100va at 18vac
which is basically what 200va 18+18vac toroid is. due to the series/parallel nature of the part you made, id think the combined coils should have about the same inductive and resistive properties as a single secondary coil (half of a center tapped secondary).
so yes, theoretically, mathamatically, its the same. (unless you wanna do all the math for the EM fields from the copper thru the core...)
realistically, its not, but who knows if 2x100va is actually better or worse than 1x200va.
the 100va transformers themselves are prob smaller than the 200va transformers (tho i highly doubt half the volume), so your may be giving yourself more options when making an enclosure for your system. (i remember reading that toroids should be mounted close with their center axis perpendicular to each other, so as not to couple EMI or something.)
Old 11th January 2007, 02:31 PM   #39
I got a buncha 100VA 25+25 trannies and I'm wondering what to do. 100VA is really not big enough to drive a pair of GC channels but two of these trannies...each one driving its own recitifier board and GC channel could be pretty cool...
Which toroidal is ok for the LM3886 and speakers 4 ohm?Hide this!Advertise here!
JBL active speakers using LM3886 pinkmouse Chip Amps 40 17th January 2009 12:21 AM
Toroidal for LM3886 Jordan Roy Chip Amps 10 27th October 2006 07:05 AM
newbie toroidal question (LM3886) cb951303 Chip Amps 9 30th April 2006 05:08 AM
LM4780/LM3886 to power large speakers drfrink24 Chip Amps 22 1st April 2005 09:57 PM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 03:41 AM
