| Chip Amps Amplifiers based on integrated circuits |
#21 | |
If the series transistor turns on it will swing high very rapidly and if the largerof the two capacitors is at the output of the regulator this would look like an instantaneous short circuit that could move the series transistor out of its Safe Operating Area. It may be wise to put a 1000 uF at the recitfier end as well. If I misunderstood you then I apologise. Kind regards Nico |
#22 | |
GC's need about 1000uF as close as possible to the chip. In the PSU the caps can be minimal, unless using a regulated or snubbered supply. Then go as high as you want!
"Everything should be made as simple as possible, but not simpler." - Einstein |
#23 | |
The devices will never dissipate that much heat, especially with a music. If is is that much of a problem double up the 3886's.
MikeW |
#24 |
Thanks, Nico. Most GC kits seem to have large caps near the chip...the TechDIY one is not an exception although they are a little farther from the chip than let's say the AudioSector ir Chipamp kit. These two latter kits differ a little on how the caps lay out on the rectifier board.
AudioSector Kit - Two small 10 uF electrolytic caps at the unregulated rectifier board, two large 1,500 uF at each V+ V- bank...no other caps anywhere at the default configuration. Chipamp Kit - I can't really comment on this one but I think that it's a snubberized power supply design with very large caps at the rectiifer board. TechDIY - For some strange reason, the designer does not bundle a rectifier board kit. There are two large 1,000 uF caps on the amp board. The designer of the TechDIY kit (jackinnj) set up various layers of cap protection on his board. I skipped some due to interference with the heat sink and some just out of a minimalist/lazy impulse. The amps without all these seem to work fine but I am curious if I'm giving in on some easy enhancement. The distance between the rectifier board and the amp board is almost none. NicoRas...thank you for your persistence on my inquiry...it is refreshing on this forum ![]() Attached is a pic of the "test mule" amp showing the relative position of the components. |
#25 |
This is the layout of the various caps on the TechDIY board. I skipped all except the large 1,000 uF caps and the little 10 uF cap on the recitifier board, of course.
I skipped C2, C5, C6 and C7. I am very curious about the one on position C7 since that would be an easy add-on right now and the motivation for my original question.
#26 |
what is the black link in the middle. That electrolytic standing up from the board, what is it? Why did you omit all those caps from your installation? R6 still does not match R2. What is your output offset? have you tried to optimise this? 20k pot into 10k Zin is too high. Have you tried to reduce it to 5k or 2k? |
#27 |
With regard to your statement of lowest off-set being attained making R6 equivalent to the feeedback resistors in parallel is not entirely accurate. Off-set is a DC component. The statement would only hold true if you did not have an input capacitor and the volume has set to minimum. From what I suspect is that you got the lowest off-set with the 1K by coincidence and it may be different for another chip. |
#28 |
BTW those were the default values from the TechDIY page. My adaptation is a lot simpler and that's why I'm asking about what to add back in.
This is how mine is laid out. |
#29 | |
The other issue was packaging...the heatsink interfered with the solder holes for the two little caps (C5 and C6). Again the result hasn't been bad... |
#30 | |
Why are you going mono? |
| JBL active speakers using LM3886 | pinkmouse | Chip Amps | 40 | 17th January 2009 12:21 AM |
| Toroidal for LM3886 | Jordan Roy | Chip Amps | 10 | 27th October 2006 07:05 AM |
| newbie toroidal question (LM3886) | cb951303 | Chip Amps | 9 | 30th April 2006 05:08 AM |
| LM4780/LM3886 to power large speakers | drfrink24 | Chip Amps | 22 | 1st April 2005 09:57 PM |
| Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) | Rixsta | Pass Labs | 10 | 23rd April 2004 03:41 AM |
