My_Ref Rev.C power supply
Old 15th December 2006, 04:16 AM   #1
Jordan Roy is offline Jordan Roy  Canada
Default My_Ref Rev.C power supply
Hi guys!
I will soon have the My_Ref Evc.C pcb done. I am now searching for a solution for the power source.
I would have access to one of those, (the LCA), power supply for the alimentation part, and cheap. Do you think it would fit? It is an LAMBDA industrial regulated power supply, capable of 2x24v secondary.
Also, I have started to read the MyRef thread to find what is the correct way for the power source, but there's way too much info.
Anyone could tell me clearly what is that design requirering as transfo or PSU?
Thanks a lot!
Jordan
Old 15th December 2006, 06:11 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
DId you make your own PCB cause those boards each had their own PSU onboard, all you needed was a transformer or two...
Old 15th December 2006, 01:35 PM   #3
Yes I made my own, based on the Twisted Pear's site PCB.
So, for the MyRef Rev.C, all I would need is a 24v secondary transfo? Does it absolutely have to be 24v? And what is the seggested primary VA ?
Sorry about the noobness of the questions, but I searched a lot, and found no clear answer...
Jordan
Old 15th December 2006, 01:41 PM   #4
Nordic's Avatar
again speaking from memory 160VA for seperate trafos, and 250- 300 if you are going to share one...
As long as you don't go to far above or below 35V after rectification you should be ok until you turn the knob almost to the end. so feasably 2 x 22 to 26VAC secondaries could do the trick.
As a recommendation, there are 2 1W 1k resistors, you need bigger wattage for those... try a 2W it gets very hot, also make sure the zener diodes are not flush with PCB so that air can circulate around them.
We just need to wait for Russ or Brian, I am too lazy to go look if their circuit included the PSU bit...
Do you see any transistors in your schematic?
Old 15th December 2006, 01:57 PM   #5
Thanks for your info on this! Really appreciated.
Here is the schematics
Jordan
Old 15th December 2006, 02:10 PM   #6
troystg is offline troystg  United States
troystg's Avatar
If you made the twisted pair kit then all that is required is the transformer as Nodic stated.
Mine sounded great straight off the soldering bench! Good luck with yours..
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 15th December 2006, 02:13 PM   #7
Panelhead is offline Panelhead
Default Moved?
Troy,
When did you leave the great state and go back home?
George
Cheapest is bestest
Old 15th December 2006, 05:23 PM   #8
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
If you etched your boards from the mono block images Russ posted, the power supply is included on each board, along with the speaker protection circuitry.
All you need is a trafo, as mentioned earlier. 24V is the ideal. 25V is fine as well. I actually recommend higher than 160VA per channel. I recently build a couple RevCs using a 250VA for a pair (buyers choice) and the rails do sag quite a bit at higher output levels. 250VA per channel or 400 for a pair would be ideal.
I think Antek (ebay seller) has 400VA 25V torroids for not too much. [EDIT: Doesn;t appear to have any right now]
Old 15th December 2006, 06:19 PM   #9
Nordic's Avatar
The schematic is not complete, the PSU and DC protection parts are missing.... however the monoblock PCB as said above will need these parts too..
Old 15th December 2006, 06:50 PM   #10
Correct. Mauro initially drew the RevA as a 2-page schematic. RevC revisions were only to the first page, which is what you see there. The second page, with power supply and protection circuitry is present in the schematic.
You can see the whole thing here: http://www.diyaudio.com/forums/attac...amp=1116856847
from this post:
http://www.diyaudio.com/forums/showt...939#post647939
My_Ref Rev.C power supplyHide this!Advertise here!
MY_REF technical description mauropenasa Chip Amps 14 2nd December 2016 12:40 PM
my_ref revC group buy (Mauro Penasa LM3886 design) schro20 Group Buys 650 17th October 2010 11:42 PM
MY_REF EVOLUTION by MAURO PENASA goldkenn Chip Amps 8 25th September 2007 04:50 PM
FS: Mauro MY_Ref Rev.A fully stuffed board DcibeL Swap Meet 3 6th October 2006 11:59 PM
FS: Mauro My_Ref Rev.A & Freebird & more DcibeL Swap Meet 4 27th February 2006 07:12 PM
Copyright ©1999-2017 diyAudio
