something with LM4702 and Power FET
Old 14th December 2006, 04:39 PM   #1
FastEddy is offline FastEddy  United States
FastEddy's Avatar
Default something with LM4702 and Power FET
The suggestion is for a new thread for the National LM4702. My choices would be to use power MOSFET or HEXFET drivers, rather than Darlington pairs or other scenarios.
The LM4702 would make a most excellent ~ 4 to 6 watt stereo headphone amplifier from +/- 12 to +/- 20 VDC rails !!
This chip amp can have some really excellent THD specs (as low as 0.0006% !) with careful attention to details, ground loop questions, etc., etc.:
" ... At 10 Volts RMS output, THD+N is about 0.005% across a 20 Hz to 20 KHz bandwidth ... It steadily drops to about 0.0015% at maximum output voltage. ..." (error ?) " ... At very low output voltages the data sheet shows that THD+N rises to over 0.1% ..."
Personally, I am also interested in balanced inputs for "pro audio", better quality connectivity between pre-amps and remotely powered and bi-amped speakers (power supply, EQs and LM4702 + drivers in each speaker), etc..
Some origins:
http://www.diyaudio.com/forums/showt...22#post1081722
http://www.diyaudio.com/forums/showt...threadid=65421
Some references:
near the beginning = http://www.diyaudio.com/forums/showt...01#post1079301 ...
http://www.diyaudio.com/forums/showt...06#post1081506 ...
Resources and DIY references:
http://www.national.com/an/AN/AN-1490.pdf &
http://www.diyaudio.com/forums/attac...amp=1165969434
http://www.chip-pcb.cn./ = recent kits & modules
http://www.tech-diy.com/Amplifiers/LM4702_Sanken.htm = very good DIY board
http://www.werple.net.au/~gnb/audio/lm4702.html = indepth w/ pics and suggestions
"Truth is one, paths are many ..." The Dali Lama
Old 14th December 2006, 04:45 PM   #2
with just 6V to play with you will be restricted to Lateral Fets. With low Gm you may even run out of drive for these as well.
regards Andrew T.
Old 14th December 2006, 04:53 PM   #3
FastEddy's Avatar
Like these: "Next Generation Hexfet / Lateral MOSFET ..." ( from: http://aussieamplifiers.com/nx150.htm ) ...?
Old 14th December 2006, 06:08 PM   #4
FastEddy's Avatar
Default More '4702 DIY references:
Completed group buys and documantation for a very good LM4702 power amp:
http://www.diyaudio.com/forums/showt...threadid=79322 ... links for group buy of Veteran's '4702 project = looks good! (board layout: http://www.audio.webd.pl/images/lm4702_pcb.gif ) ... power MOSFET drivers ... oh boy!
Partially assembled: http://www.audio.webd.pl/images/lm4780_pcb_5.jpg ... http://www.audio.webd.pl/images/lm4702_pcb.jpg ... http://www.audio.webd.pl/images/lm4702_assemb.jpg ...
" ... I do feel the chip should be on a small heatsink it runs pretty warm. ..." http://www.diyaudio.com/forums/showt...757#post948757
Origins of the National design?: http://www.ampslab.com/c200cfp.htm
Almost complete: http://www.diyaudio.com/forums/showt...514#post950514 ( http://www.audio.webd.pl/images/lm_amp.JPG & http://audio.webd.pl/images/lm4702_amp_test_1.jpg )
Further circuit improvements: http://www.audio.webd.pl/pdf/monster_amp.pdf
Almost there: http://www.diyaudio.com/forums/showt...373#post952373 ... and ... http://www.diyaudio.com/forums/showt...867#post953867
Veteran's Printed Circuit Board Redesign: http://www.diyaudio.com/forums/showt...11#post1030511 ... newer schematic: http://www.unisonus.com/pdf/monster_amp.pdf ( http://www.unisonus.com/projects/lm4702_amp.html ) ... technical results: http://www.diyaudio.com/forums/showt...01#post1058601 = 0.004 THD at >> 70 Watts !! ... good show!
another '4702 DIY builder: http://www.diyaudio.com/forums/showt...00#post1033700 w/ pictures
Old 14th December 2006, 10:12 PM   #5
SpittinLLama is offline SpittinLLama  United States
Read that LM4702 group buy thread by Veteran. I tested his first board and put some info in there about it. Although THD didn't get below 0.005% the stability is very good and the comp caps can probably be reduced for higher slew rate. They were 30pF but may be able to go down to 15pF. It sounds great to me but I am no listening expert so that means little. I am working on a board more like his monster amp schematic, more devices on each side for higher power. I have only use the 1530/201 pair but am going to try the 1058/162 pair also. Biggest contrionutor to THD on the board I tested is the 2nd harmonic. Others are down really low.
For low power I would think the LM4562 with a buffer output stage might be a better ideal. No reason to use at +/-12V when maximum is like +/-75V.
-SL
Old 14th December 2006, 11:36 PM   #6
FastEddy's Avatar
" ... No reason to use at +/-12V when maximum is like +/-75V. ..."
Yes, the lower the rail voltage, the poorer specs like THD, etc. My thoughts os this as a headphone amp (only) may be amiss ...
Old 14th December 2006, 11:41 PM   #7
FastEddy's Avatar
" ... I am also interested in balanced inputs for "pro audio", better quality connectivity between pre-amps and remotely powered and bi-amped speakers ..."
Anyone have thoughts about this?
Old 16th December 2006, 05:02 PM   #8
FastEddy's Avatar
... more ...
http://www.diyaudio.com/forums/showt...43#post1083343
http://www.diyaudio.com/forums/showt...03#post1083403
http://www.diyaudio.com/forums/showt...06#post1083406
Old 17th December 2006, 01:53 AM   #9
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Balanced inputs? One word: Transformers.
se
Old 17th December 2006, 03:20 AM   #10
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Transconductance for one Latfet is 1 S.
something with LM4702 and Power FETHide this!Advertise here!
Power supply for LM4702 rtarbell Power Supplies 16 22nd April 2016 07:59 AM
XDA-1 -- A symmetrical power amp utilizing LM4702 Russ White Chip Amps 35 24th September 2007 09:44 PM
Lm4702 on pure dc power steven344 Chip Amps 1 14th December 2006 02:34 PM
Copyright ©1999-2017 diyAudio
