I have a 60VCT transformer laying around and was thinking about using it for a high-power LM4780 project. I want to drive two 8" midbass per chip in parallel mode. By my calculations I should get +/- 40V rails give or take a few volts. This is within the chips capability but seems awful high compared to other designs. What will happen? Just get too hot to use? Can anyone figure out how hot it would get at various power levels?
how big is the transformer?
Depending on how the rails hold up under load you might get away with it...
This is one of those cases where less is more, if your transformer and caps are big enough to stay close to 40v under load you are going to pop the chip...if on the other hand your rails sag into the low 30s under load you may have no problem at all...
Not often you hear underbuilding advocated on diyaudio...
Of course you could simply drop a few volts using a CRC or CLC power supply in which case the problem will go away and you'll have a better power supply to boot.
You should download the spreadsheet from NatSemi, it gives you power output from the chips as a function of load and voltage, it's a very handy thing for those that want to build gainclones...
HTH
Stuart
HTH
Stuart
sure...
Considering just one of the the 2 rails (the other being a mirror image): a CRC power supply uses a capacitor, then a resistor, then another capacitor to generate a smoother rail than could be generated using the caps alone.
A CLC replaces the R with an inductor, typically a milliHenry or two which is a little more efficient than the CRC, more voltage for the same ripple, or less ripple for the same voltage...
As an example, simulated using PSUD2:
With 30v secondary, 2.5 Amp load, 10000uF caps
CC: ~38v, ~1.5v ripple
CRC: ~35v, 600mv ripple, 0.5 ohm, 5W resistor
CLC: ~37.5v, 600mv ripple, 1.1mH (0.1r)
The caps are the same in the 4 cases.
The inductors can be expensive if you get high end (air core etc) ones, but since you are looking to lose a few volts you probably don't want the very lowest resistance inductors anyway...
If you have the time and interest I'd recommend trying PSUD2, it's an awesome tool for power supply design:
http://www.duncanamps.com/psud2/index.html
Stuart
Stuart
The bigger problem might be mains voltage variations. I use 24 V transformers and get 35-36 V rails, which is consistent with calculated expectations. To my big surprise I have measured 40 V rails on several occasions though... considering the 35 V rated caps I was not too amused.
I have measured the rails. 43V-OFF and down to about 37V-CLIPPING. Overall I think I have a strong power supply (enough caps and large enough transformer.) I just think I went a little off reading the first page of the datasheet and thinking that anything under 84V(on) would be good... stupid marketing hype got me again!
CRCLC...
Same overall params I used before:
CRCLC: 34.3v, 110mV ripple
Kind of makes you wish the program had a function where you could give it a budget for components and have it permute the possible components to find the best fit...
ie is it better to have CRCRC, with smaller caps than single big C, or some other variation...bigCRsmallC etc
Stuart
Stuart
I'm a bit confused. Reading your first post it and thread title it appears you are going to drive two 8 ohm speakers wired in parallel to be 4 ohms and then configure the LM4780 in parallel mode to drive them? Is this correct? If so you're wasting time, just drive each speaker from one ouptut. No need to do any parallel of anything. The output power will be the same at 8 ohms on each channel as 4 ohms on the channels in parallel. In fact, single 8 ohms per channel is better since you will have resistors to connect the outputs in parallel that drop power and add noise. If I don't understand than ignore all the above.
The chip should not pop just run hot. The LM4780 is recommended to run at +/-35V with 8 ohms/Ch so +/-40V is going to run hotter. Don't expect it to run sine waves all day without over heating but with music and a big heat sink you might get away with it. The other thing to be careful is the 84V (+/-42V) and the 94V (+/-47V) ratings. Exceed those and you're asking for blown chip. Might need to drop a little voltage and maybe add some sort of protection for high line condition.
Good luck,
-SL
Good luck,
-SL
- Chip Amps
- LM4780 4ohm @ +/-40V rails
