Old 12th December 2006, 01:15 PM   #1
Default multi-channel hum, one transf, multiple PS
I know this has been discussed ad nauseam, but......
Here is my wiring scenario:
115AC x2 -> 36VAC X2 -> 4 position terminal block
From the terminal block, I run 4 wires (2 x 36VAC) to each of four power supplies(BR/caps). The "gnd"s are commoned on each PS, not at the terminal block. There is only one BR to get the split rails.
SafetyGround->Chassis and transformer ES - not connected to anything else yet...
I get non-variable 60Hz hum with inputs shorted. Not a huge amount, but enough.
1) Should I connect the 2 "gnd"s at the terminal block before they run to each PS
2) Where should I put the disconnecting network to the ChassisGnd? From each PS? At the terminal block? Do I need one for each PS?
Thanks in advance...
Dale
doing my part to Keep Austin Wierd.
Old 12th December 2006, 04:32 PM   #2
Bob Cordell has just posted a grounding scheme which should need only one disconnecting network. Power supplies.
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 07:29 AM
multi channel t amp kendt Class D 2 4th April 2009 11:12 AM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
multi-channel AMP? JAZZ2250 Solid State 1 15th September 2002 09:10 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
