gainclone vs. symasym amp
Old 13th December 2006, 01:50 PM   #11
BlacK_Chicken is offline BlacK_Chicken  Germany
Default right decision!
Hello,
I Think you'll be fine with that setup.
The LMs are really easy to start. If you like you can have my board layout, wich I posted on "hifi-forum". A little practise in etching boards comes in handy for the symasym.
I will start my own symasym (has been planned long before the K+T-article) these days now. But still, the symasym is far more expensive than a gainclone. One MJL for 6.20 Euros, means I could buy 5 Gainclone-Chips for the price of 4 outputtransistors for the symasym.
BTW if you are taking more Quality Parts on the Board the symasym is way more expensive than stated in the Article in K+T (i.e. they buy their Trannys bei "reichelt" and use the BC-types. I had very bad experiences with their power-transistors, in my first discrete designs.)
Good Luck!
Black
Old 13th December 2006, 02:16 PM   #12
student is offline student  Austria
hi
another really simple question
how much watts should have my soldering station ?
at the moment i have a single 15 watts soldering-stick.
i could buy a 10 watts station with a regulator for 100°-400° temp for 40 €.
is that quite enough or do i need more watts ?
Old 13th December 2006, 04:19 PM   #13
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
10 or 15 Watts is not much if you want to solder everything in an amp. I have 50 and 80 W temp controlled soldering irons.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 73 pcb's in order. 73 paid.
Old 13th December 2006, 04:53 PM   #14
Default definately more!
Hello
I do have a second soldering Iron, ERSA 25W, but I do only use it for really small components on PCB, soldering a mains Fuse/plug or something else that big is impossible.
I also do have another 80W unregulated for these jobs, to be honest I only use the big one...
BTW more power is a plus, many parts can stand high temperature only for short time-period. The more power you have to heat your Part (R, C, IC) the faster your soldering is done and its less harmful for your component.
Greets
Black
Old 14th December 2006, 10:10 AM   #15
ok thx
i'll buy a soldering station this week and maybe the parts for the gainclone amp.
do i need a professionally corroded circuit board for the gainclone or can i connect the parts with isolated wires at the back ?
Old 14th December 2006, 10:14 AM   #16
http://cgi.ebay.de/Platine-Chipverst...mZ290036837978
is this circuit board ok for the gainclone ?
cause i heard that one resistor should be placed as near as possible to the lm3886 chip.
wich circuit borad would you advise ?
Old 14th December 2006, 06:43 PM   #17
If you dont like to etch your own, I would give them a try. Very Cheap.
In my layout, I am mounting the sensible feed-back resistors on the copper side, directly under the chip. This insures the shortest distance, same as with ptp-wirering.
Greets
Black
Old 14th December 2006, 07:09 PM   #18
thx
ill buy a normal circuit board which is unconnected at the back. is the cheapest method.
i think a good soldered self made circuit board with isolated wires at the back side as connection of the electronic parts will work as good as such a "professional" made circuid board.
frage, darf man hier auch auf deutsch schreiben ?
Old 14th December 2006, 07:21 PM   #19
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Nein, nur Shakespeares Sprache.
Old 14th December 2006, 07:44 PM   #20
na geh ;(
gainclone vs. symasym ampHide this!Advertise here!
symasym 5.3 parts 406vette Parts 10 13th June 2017 07:02 PM
Troubleshooting your Symasym anatech Solid State 236 14th April 2015 02:47 AM
Symasym PCB Khron Solid State 58 17th May 2012 07:18 AM
FS 2* DIY Symasym boards Andypairo Swap Meet 11 1st February 2009 01:59 PM
