Need help fo 100w+per channel stereo chip amp - Page 2 - diyAudio
Old 10th December 2006, 02:00 AM   #11
Way better than expensive stores!
The sound quality will thrill you.
Poor stereo mix? Switch to mono! Perfect.
Old 11th December 2006, 10:18 PM   #12
Back on the transfo... do I need 1 or 2... I will be running this chip in parallel at 4ohms... Please give me your recommendation as for the brand and size.
Max
Old 11th December 2006, 11:31 PM   #13
Normally, one transformer is used. It will have to have TWO secondaries. This is where your experienced friend should come in. Have him explain what you need in a transformer. It's the one single most expensive component. So you don't want to get the wrong one.
Either one that I linked to you will work.
Old 12th December 2006, 12:57 AM   #14
Do you think the amp would fit with the transfo in that case ?
http://www.iagaudio.com/proddetail.asp?prod=CH%2D02
Old 12th December 2006, 01:20 AM   #15
It's a beautiful case and big enoug, but you are getting ahaed of yourself.
Best to get the components and asseble the amp,then, concider an enclosure. Don't forget, you need some good heat sinks for these chips.
I lack knowledge of heatsinking techniques so, I just get the biggest I can afford. THEN, I concider the enclosure.
DON'T FORGET THIS! You must insultae the chip from the heatsink. Search Sil Pad 400 on this forum or Google.
WTB: STK043 stereo amplifier chip gilwe Solid State 7 18th January 2009 08:44 AM
2-channel parallel 100W GC using LM3886 scone Chip Amps 30 28th August 2007 03:19 AM
how to mix stereo into center channel bob_v5 Solid State 0 14th February 2006 09:07 PM
Is it Chip or BJT in this Stereo Amp? boxedin Solid State 4 25th December 2005 03:44 PM
Stereo Chip Amp - one transformer or 2? groyne Chip Amps 12 18th May 2004 07:22 PM
Copyright 1999-2017 diyAudio
