| Chip Amps Amplifiers based on integrated circuits |
#11 |
Hi J,
what voltage are you running your chip from? I assumed that you could achieve about 24Vpk from +-30Vdc. |
#12 |
I got a transformer with dual 30 volts secondaries, after rectifying that should be around 40 volts right? That may be a bit to much for the 4780 chip so then I regulate it down to whatever but atleast 34 volts since the lm338 requires atleast 6 volts regulation (i think). So maybe 30-34 volt supply to the chips. And again lm338 max output 5 amps, and I want to run one chip in paralell config per channel and there will be two channels, so two chips to drive. I hope you understand, cause i lost myself somewhere...
#13 |
Why parallel and not bridged?
#14 |
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#15 |
A 4ohm load is going to demand a lot more current than an 8ohm load.
A 5A limit from the regulator is not, in my opinion, going to deliver the goods. |
#16 |
Also a 2x40 VDc supply is a bit to much for a 4 Ohm load. I suggest looking for a transformer with a 2x22 Vac secundairy. Given the very good PSRR of the Overture chips, I do not see the need of a regulated supply.
#17 |
I've bridged a LM3875 chip amps (Audiosector kits - Dual Mono) running 6 ohm (nominal) speakers without any sonic or heat problems. Admittedly, listening levels are always kept at low to medium levels and the chips are well heat sinked.
#18 |
#19 |
I'm using two 300va transformers with 22v secondaries. This feeds the chip amps with 31 volts DC.
| 4780 stereo, parallel, bridged, single sided | gmphadte | Chip Amps | 12 | 12th March 2007 11:42 AM |
| P3A Bridged Into 4 Ohm load | kinser | Solid State | 0 | 12th August 2005 01:09 PM |
| Bridged 4780 with 35V rails | akunec | Chip Amps | 0 | 20th October 2004 12:25 AM |
| 4780 Bridged PCB designs? | Nappylady | Chip Amps | 0 | 28th April 2004 05:25 PM |
| can tda1514a bridged hold 4 ohm load? | rulezzz | Chip Amps | 7 | 6th January 2004 01:14 PM |
