| Chip Amps Amplifiers based on integrated circuits |
Hi all..
With AndrewT, Pink Mouse and the other friends assistance i am nearly finish my 2+1 project. But i want to change my subwoofer filter design (which made with Princetons PT2350). By TI's Filter Pro software i designed a new Butterworth / Sallen Key type 130Hz 4 pole LPF and added a preamp (6dB) stage to it. I kindly request; please investigate my new design and give some comments on it! May it works perfect or not??? Thanks a lot in advance... |
#2 |
do you realise you can implement the S&K 4pole Butterworth with Equal Value S&K filters that incorporate gain. The resultant gain for the two cascaded 2poles are +1.23db & +6.98db = +8.21db Close to your required +6db. The nice thing about EV S&K is that all the resistors are the same value and all the caps are the same value, making matching much easier. You can also vary the Q very easily by changing the gain without changing any of the frequency components. This can all be achieved with just two opamps not the four shown. If the first opamp filter is made MFB instead of S&K then you can bass sum at the input as well. The DC block at the filter input should not be necessary. Finally, why the odd filter component values? when 2C or 2R gives Butterworth.
regards Andrew T. |
#3 |
Hi Andrew..
First of all; thank you again for your comment. But i did not do anything but TI's Filter Pro Software's results. So i gave it the cut off frequency, selected type of filter and it gives me that RC values. In fact i could calculate these values by hand but i trusted the software more. If you say; "its ok it will work perfect" i will apply it before my subwoofer amp. As the software says. The output signal is 180° different from the input @cutoff frequency (130Hz). Does it make something bad? Or just should i cross the speaker terminals on subwoofer amp? And a final question; after first stage i summed the channels via 39K resistors then put a DC blocking cap. If i remove the cap. does that situation affect the filters frequency? Because as you can see, after that 39K resistors the RC block starts so the resistors value will be increase! Isnt it? Best regards. |
#4 |
if you have no DC offset being fed into the first opamps then the only offset coming out will be the inherent opamp output offset amounting to just a very few mV. It is much more important you block or eliminate the DC offset coming from the source. All these filters assume they have a zero source impedance and an infinite load impedance. Your DC block and insistence on using the non-inverting summer will completely screw up all the calculations the Ti software is doing for you (and all the effort you will put into trying to measure those differing cap values). Get rid of it!!!!
regards Andrew T. |
#5 |
Ok then. I will remove the summing stage and DC blocking. And will put the DC blockings to each channels input (but i have already have caps in stereo power stages input!). But at this time does it affect the channel speration? Because i got some problems with that 39K summing resistors in past!
#6 | |
Hi, you're not listening
regards Andrew T. |
#7 |
I somewhat like gain=2 S&K filters. with a gain of 2, the capacitors can be made equal in value. the gain setting resistors are also equal value. the Q is changed by the two other resistors. this is easy to build for arbitrary Q, fixed filters.
gain=1 filters are better suited when the ratio of capacitors makes one cap 2x the size of the other.
if only it could be used for good, not evil... |
#8 |
To Andrew;
Objection; i am listening but may be i did not understand you clearly! To block DC from source i say "i will put the caps each channels input" means i will put 2µ2 caps to each seperate main input. Is it ok do you think? And still i have questions about channel seperation problem with channel summing.. For theChris; As i understand from you; should i fix the capacitor values? and should i fix the gain = 1. Is it? I feel like silly... I have to go to an English course... Tanks a lot. |
#9 | ||
it seems to be a mis-understanding Quote:
DC at the input to the filter will cause the opamps to go asymetric and they will not perform well that way. The output offset of the opamps (if they are set up correctly) is negligible (0 to 4mV). But the offset coming from the source could be many volts. Block the source and the problem goes away. Fit a good quality 10uF at the output of the source. If you believe you need more then parallel with a 220uF bipolar 16V or 25V (Rane recommend Panasonic) Quote:
regards Andrew T. |
#10 | |
because of the difficulty in finding good ratios of caps (in a general case), i like the gain=2 circuit. I'll try to post a picture of a normalized circuit later
| Room design, DIY in-wall speakers, IB subwoofer, comments? | wigginjs | Multi-Way | 10 | 3rd July 2008 08:12 PM |
| My Subwoofer Plate Amp - Comments? | soundNERD | Chip Amps | 13 | 31st March 2004 12:41 PM |
| Comments on box and filter.. | Buhl | Multi-Way | 0 | 11th September 2003 08:39 AM |
| Seeking comments regarding dedicated dual subwoofer use with main speakers | UncleJessie | Subwoofers | 2 | 16th April 2003 06:38 AM |
| Comments on Decware WO-32 subwoofer? | mjgraves | Subwoofers | 2 | 6th August 2002 03:38 AM |
| Page generated in 0.17553 seconds (59.90% PHP - 40.10% MySQL) with 11 queries |
