| Chip Amps Amplifiers based on integrated circuits |
I'm still new at this so y'all will have to forgive me. I know that there is no such thing as a dumb question, just consider me an inquistive idiot.
![]() I've seen a number of chipamps that have the large-value caps w/o their clothing. Is there a reason to remove the wrapping aside from asthetic ones? |
#2 |
Technically, there shoud be no difference.
But as always with things like these, those who remove the wrapping do so because they feel it improves the sound in some subtle way. And to a degree, that's probably true. In their ears, it does sound better. Rune
Do wizards use spell checkers? |
#3 |
The plastic jacket is insulation so don't remove it unless you know what you are doing!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
The jacket also shows the polarity so make alternative arrangements when removing.
#5 |
It also allows cheaper caps to be substituted for more expensive ones.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
You cynic Al!
So it was TV that did for poor Alexander Litvinenko!
#7 |
Voodoo and black magic
#8 | |
The fact that you are asking about it indicates that you have the potential to rise above the stupidity of magic audio. It is obvious that you don't blindly believe every bit of nonsense you read on the internet. I applaud your inquisitiveness and hope you will continue on your quest for truth. I_F |
#9 |
If you install Black Gates in some sort of supporting blocks, see pic here: http://www.diyaudio.com/forums/attac...amp=1143477205 and use standard size Forestner bit to make the holes, you need to remove capacitor's 'wrapping', otherwise the cap won't fit (sizes 7/8 and 5/8 dia).
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#10 |
also makes it a little harder to reverse engineer simply by looking at it...
| Proper Wire for Wire Wrapping | DreadPirate | Parts | 5 | 19th August 2008 09:58 PM |
| Wire Wrapping Tool On the Cheap | DreadPirate | Parts | 1 | 28th May 2008 11:14 PM |
| Bracing driver to box, deadening basket and wrapping magnet in felt | tsnell | Multi-Way | 2 | 18th October 2007 02:33 PM |
| Trying to remove RF | jduffy | Chip Amps | 8 | 26th February 2007 11:36 AM |
| Page generated in 0.39634 seconds (21.98% PHP - 78.02% MySQL) with 10 queries |
