Old 30th November 2006, 04:43 AM   #1
Default Audiosector kit: adding a pot
I'm a bit confused about how a pot is actually wired up to the audiosector kit. According to Brian's userguide, the pot's wiper simply goes to "IN" on the board. So do the other resistors (220R, 20K) still remain on the input? This is different to National's schematic which shows just a 10K pot and 1K resistor.
Also, I've got the choice of either a log 10K or a log 50K pot. Which would be a better choice? My inputs will only be computer soundcard, USB DAC, or iPod.
Thanks.
Old 30th November 2006, 04:53 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
Someone is going to tell you to use the search function any minute now.
source connects on the side of the pot to which you turn the pot for full volume. middle pin goes to amp, other pin is for input...
10K is fine.
Old 30th November 2006, 05:15 AM   #3
Bob0513 is offline Bob0513  United States
audio input goes on to one end, wiper to amp in, other pin to ground. 10k or 50k will both work.
Old 30th November 2006, 06:56 AM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The pot connects to IN and SG on the board, don't worry about other components there, they stay where they are.
You can use either of the pots you have, I would probably go with 50K.
Attached is a pot connection diagram.
Don't use a search function, it's a waste of time.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th November 2006, 10:54 AM   #5
I was expecting some flak about using the search, because having used it I know there are a lot of posts about gainclone pots. Unfortunately I couldn't find a definitive answer to the specific questions I've raised.
Thanks to everyone for your help with this, especially Peter. I'm sure I won't be the only one to benefit from these informative replies.
Old 30th November 2006, 03:28 PM   #6
CarlosT is offline CarlosT  United States
I think that it was Peter also that had a tremendous comparo of different pots...I wound up buying some carbon Precision pots based on his work. Thanks, Peter.
Old 1st December 2006, 03:03 PM   #7
Although the title is not totally fitting, this guide was pretty good
http://www.tocos.com/guideline%20and%20precautions.pdf
So for a simple three-terminal, single pot, Terminal 3 is signal input, Terminal 2 (the wiper) goes to the amp's input and Terminal 1 goes to ground?
Old 1st December 2006, 03:13 PM   #8
Does Terminal 1 have to go to ground?
Old 1st December 2006, 03:30 PM   #9
troystg is offline troystg  United States
troystg's Avatar
I hate to ask but what are pins 1 and 5 for? I have the same Noble pot and really do like it but I have always been curious what the extra pins were for.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 1st December 2006, 03:41 PM   #10
Yes
On the pots I had those pins were not connected. But maybe in some versions they are used for 'loudness' control.
www.audiosector.com
Fs: Audiosector Nos Dac r8833 Swap Meet 6 14th February 2009 02:59 AM
Adding tube to Audiosector GC marcus7601 Chip Amps 53 28th August 2008 11:38 PM
AudioSector NOS DAC $225 obo nodiak Swap Meet 2 8th November 2007 05:10 PM
Audiosector NOS Dac Darrell Morgan Digital Source 7 8th August 2007 02:55 AM
audiosector dac karma Chip Amps 3 7th December 2005 01:04 AM
Page generated in 0.15081 seconds (66.00% PHP - 34.00% MySQL) with 11 queries
