Old 29th November 2006, 12:03 PM   #1
Default Gainclone and center tap
Building my first Gainclone here with LM3875-kit from Audiosector.
The transformer i have is with center tap, ie three wires. I plan on using on psu-board for both channels.
I have read the manual and searched but i am still not sure how to connect it with the Rev. B kit.
As i have done now, i have only 4 diodes on psu-board as described in manual. The center-tap is connected to PG+, also as the manual says, but if i do that i am short of one PG+ that should be connected to the other two boards?
Old 29th November 2006, 01:20 PM   #2
I think i got it.
Old 29th November 2006, 02:12 PM   #3
sounds like you discovered that each amplifier board needs only one power ground connection. The two PGs are directly connected on the amplifier PCB.
As an aside, I think the performance of the stereo amplifier set-up is improved if you run two PSUs fed from a pair of shared secondary tappings. i.e. a separate rectifier and pair of smoothing caps for each amplifier.
regards Andrew T.
B&W LM1 as L&R, which center ? jay1st Multi-Way 11 16th January 2008 07:00 PM
Center-Center Distances and Horns BassAwdyO Multi-Way 8 15th January 2006 01:01 AM
center sidd_raj2002 Subwoofers 1 2nd December 2004 03:22 PM
Center to Center of Drivers 29" apart in proposed config - Problems?? Ken L Multi-Way 14 3rd November 2003 12:49 PM
Page generated in 0.12393 seconds (41.25% PHP - 58.75% MySQL) with 10 queries
