Old 27th November 2006, 10:22 PM   #1
alexan is offline alexan  Greece
Default LM3886 clipping at 13v rms
Hi
I have a problem with the gainclone I made, please take a look at the attached picture.
The picture output signal is a 200Hz (but also happens to 500hz of 1Khz) and about 13V RMS, this is actually where the clipping starts but only for the lower half of the signal.
My PSU is 31.6v and the testing load is a resistive 8 ohm (made by parallel resistors).
The output is about 21 watts (from P=V*V/R) and is very low since the amplifier should have an output of about 40W before clipping.
Both psu rails are ok with 31v DC and very low ripple since I have 10000uf in each rail.
Can someone please suggest what might be wrong, it doesn’t seem to be the (internal) spike protection circuit.
Thank you
Alex
Old 28th November 2006, 12:54 AM   #2
gmikol is offline gmikol  United States
Alex--
One of us is reading your graph wrong...
To me, it looks like Vp-p is about 50 volts (+/- 25V). This is about 17.6 VRMS, which translates into about 39W into 8R. Judging by the datasheets, you should be below the clipping point, which is about VCC-2.7V at this supply voltage.
The fact that the waveform is only distorted every other cycle suggests to me that you're probably at the SPiKe limit. Try blowing a fan at your heatsink to see if it goes away at this level.
Good luck--
Greg
Old 28th November 2006, 11:32 AM   #3
Originally posted by gmikol
Alex--
Good luck--
Greg
Thank you for your reply.
The graph in the picture is not scaled (it's from my audio card and a measuring circuit as buffer and both are below the clipping region).
The signal is 13v rms (over the 8 ohm load) measured with a multimeter since its 200hz and the measurement is accurate.
The chip is mounted directly to a big heat sink+blower (with paste between the chip and heatsink) and the temperature measured at the chip (not the heatsink) is about 30 celsius (with a digital thermometer)
I can't explain what is wrong an the spike protection in the datasheet for LM3186 shows a different graph for when the spice protection is working.
On the other hand it seems to be a protection because if i let the chip heat this clipping occures a little lower but the output watts but the output is very low at about 20W.
The temperature measurement can't be wrong because i can even feel it with my hand.
Thank you
Alex
Old 28th November 2006, 12:44 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
I don't find it very unlikely
that your amplifier start showing clipping at +-25V
if your rails are at +-31.6 V, when amplifier is at idle.
But what is the supply voltage when you get this clipping?
Some supply can be several Volts lower under such high power
as near to 40Watt RMS.
4-5 volts is not uncommon for some amplifiers.
What is the VA rating of your trafo?
Very big trafo will not drop voltage as much
as normal size transformer.
Class A amps, have same supply voltage all the time.
But here we are talking about a lower biased Class AB.
Why is unsymmetrical clipping showing?
Yes, because LM3886 just like LM3875 is not a symmetrical design.
lineup
Shows that the good LM3875 is not at all symmetrical
( LM3886 is almost identical, basically )
lineup
Old 28th November 2006, 01:48 PM   #5
lineup
Hi
The graph i posted is not scaled, the true signal amplitude is 13vrms (+-18v peak or 36 peak to peak) at a resistor of 8 ohm which is about 20W rms.
The psu is from 2 separate transformers 300VA/ 24v AC each and are center tapped and rectified with one bridge and the center tap for ground.
Both plus and minus psu rails have the same voltage because both transformers were bought together and have the exact same secondary windings
The +- 31.6v DC (measured with full load and an ac ripple of 30mv) is very stable since i have only one amplifier connected to the transformer and 10000uf in each psu rail.
Alex
Old 28th November 2006, 01:57 PM   #6
pinkmouse's Avatar
Try knocking down the mute resistor to about 10K.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 28th November 2006, 02:14 PM   #7
I'll try the mute resistor, thank you.
In the meantime please chech the attachement of this post which is for 17.8v RMS output which is about 40 Watts.
As you can see the positive slope looks fine and the negative slope just gets worse.
Can it be a damaged IC? i just bought it and it is the first time i use it in a circuit, it also sounds fine untill the clipping occurs.
Alex
Old 28th November 2006, 02:16 PM   #8
sorry, i forgot the attachement
Old 28th November 2006, 02:32 PM   #9
ashok's Avatar
Doesn't it look like some form of instability ?
To me it doesn't look like normal clipping.
Check your supply lines with a scope. Note that the 200Hz signal has a problem with each alternate cycle. That is 100Hz and that is the ripple frequency . So is one half of your rectification having a problem ? You must check with a scope to see what's happening.
EDIT: OK your second picture shows more than every alternate cycle. Check your supplies in any case . Did you use the 100pF cap on the NFB resistor ?
AM
Old 28th November 2006, 07:01 PM   #10
lineup's Avatar
I would make a check that you have all components
put together correctly.
Especially look for electrolytic caps,
are put into circuit with correct polarity + -
And that all capacitors have got good voltage rating.
There can be is some connection, some component, that is not put the right place
or you have wrong polarity.
Or maybe one end has got bad solder and not in contact.
Also putting in a component, resistor with wrong value.
It is not too difficult to mix up, and put an 10k instead of 1k
because they look almost the same!
We can have 99 components put right
but only 1 not right,
and your circuit wont work good!
If mains is 50 Hz, Try run your test at 175 Hz... or for example 225 Hz.
Because 200 Hz is a second harmonic of 100 Hz and
full bridge rectified voltage is pulsed with 100 Hz.
50 Hz full wave recitifier
will work at 100 Hz
and produce: 200, 300, 400 harmonics
That is, if you do not use 60 Hz mains,
in which case your full wave DC will have pulses at 120 Hz,
and harmonics are 240, 360, 480.
lineup
lineup
LM3886 clipping behaviour cs Chip Amps 18 18th February 2008 04:44 PM
Clipping richie00boy Class D 2 16th January 2008 05:36 AM
Clipping GC? drfrink24 Chip Amps 29 1st April 2005 10:14 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
What is clipping? guitargully Solid State 5 25th February 2004 08:24 PM
Page generated in 0.22573 seconds (54.41% PHP - 45.59% MySQL) with 11 queries
