| Chip Amps Amplifiers based on integrated circuits |
I probably went a little overboard with this one, but couldn't resist the temptation to use those cute heatsinks. So here's my next gainclone implementation.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2 |
Very nice!
More pics of the guts? MR |
#3 |
I was concerned that those heatsinks might ring a bit, but overall appeal was much stronger than common sense and the whole creation is more of a modern sculpture than an amplifier.
The big chunk of acrylic in a center is there to add mass to the structure as well as to damp vibrations created from the outside. The white phenolic block is used to mount PS caps (stripped BG) and Hovlands coupling caps. The Black Beauty pot is at the back and the shaft tunnel had to be drilled through the acrylic. I like the see through effect, which adds lightness to the structure.There will be no cover and this is an open concept amp.
#4 |
More details of the inside.
#5 |
The structure rests on 3 spikes deliberately positioned under acrylic piece and under IC's. They release vibrational energy to the supporting shelf. You can see the effect when running a finger through the blades when holding the amp and comparing the effect when amp is standing.
#6 |
As usually I tried to use the quality posts and RCA jacks from Cardas.
You can also see through the acrylic back.
#7 |
are those heat pipes on the sides?
MR |
#8 |
Yes, those are heat pipes.
I used Hovland caps this time and I am curious how they will comapre to BG I used in my other clone. Yet, with the other one using such large caps would not be possible, it's just different philosophy of design.
#9 |
What a BEAUTY...
I was wondering; would you ever consider using a hardwood in place of the acrylic? Joe |
#10 |
I'll try hardwood with time too. I think that acrylic has better damping properties.
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 04:07 PM |
| JLH v Gainclone? | Jezz-the-Fezz | Solid State | 5 | 12th December 2005 01:08 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 08:58 PM |
| Page generated in 0.12206 seconds (71.56% PHP - 28.44% MySQL) with 11 queries |
