Old 4th March 2003, 09:28 AM   #981
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
I use the same Conrad case for my brand new Nonoz II DAC...
Old 4th March 2003, 10:19 AM   #982
Default Re: Re: Diodes
Originally posted by giolight
The FA Panasonic are the same as FC with longer lifetime or just different series?
Giorgio
FC should be the same. FA is discontinued and FC is the follow up. If you compare the datasheets, you will see the specs
are the same...
(though minor manufacturing differences could have occurred)
Fedde
Old 4th March 2003, 11:01 AM   #983
Default CONRAD CASES
Who sells those cases?
Carlos
Old 4th March 2003, 11:19 AM   #984
Default Re: CONRAD CASES
Carlos
Err.. Conrad !?
See www.conrad.com...
Fedde
Old 4th March 2003, 11:33 AM   #985
mrfeedback's Avatar
Default Bi-Polar Gainclone Suggestion
There has been some discussion lately about the merits of inverting operation VS non-inverting operation for the GainClone circuit, so perhaps it is prudent to show that an opamp circuit can be switched either way as below.
I know the circuit given is configured for X1 gain, but circuit values can be suitably changed.
I did also see a similar circuit in WW/EW circuit years ago that used a pot instead of a switch as the polarity selector.
This gave +1 through 0 through -1 gain and polarity control, and was described as being useful for selecting reverb unit return signal polarity, but alas I forget the finer details - anybody have that circuit to hand ?.
Either of these two circuits implemented correctly may be suitable to give the luxury of choice of GainClone operating mode.
This circuit is of course perfectly suitable for line level polarity control, and could easily be incorporated into a preamp or cdp output stage.
Eric.
I believe not to believe in any fixed belief system.
Old 4th March 2003, 11:42 AM   #986
UrSv is offline UrSv  Sweden
UrSv's Avatar
And I use the same for my GC except it is the slightly higher size (70 mm I believe). It is a pretty nice case actually for those who do not have a proper workshop like me (kitchen table...).
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 4th March 2003, 01:56 PM   #987
Err.. Conrad !?
Can you specify type or model? I went into Conrad's site but it's not easy to get to which models they carry.
Carlos
Old 4th March 2003, 02:11 PM   #988
UrSv's Avatar
Carlos
Already in this thread once:
Conrad article 522945 and:
http://www.diyaudio.com/forums/showt...716#post108716
UrSv
Old 4th March 2003, 03:04 PM   #989
Matttcattt's Avatar
does anyone know the exact amount of heat each chip creates at full volume? (a maximum)
i was thinking of using this diagram to bridge and parellel 4 together (4 chips) per channel and tri amp them
this would give me 224 watts per channel, per speaker and then i was going to make a seperate sub woofer driver (posibly with the same chips) and then use 4 car batteries in series to give me +-24v (approx.) and put it in my car (when i get one).
sound cool?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 4th March 2003, 04:37 PM   #990
Bricolo is offline Bricolo  France
Bricolo's Avatar
I tested my gainclone today
results: a little hum, and the output level is quite low (I wasn't using a pot, and the volume was a little more loud than a normal listening volume)
I used peter's shematic, with a 220VA 2*18V transformer, and a TDA7294 (10K and 220K resistors)
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Page generated in 0.12278 seconds (78.28% PHP - 21.72% MySQL) with 11 queries
