| Chip Amps Amplifiers based on integrated circuits |
#81 |
Banned
Okay, I'm making a gainclone... I am still not totally sure what it is... but so what?? I have some LM3886ICs... now to find something to use as heatsinks.... lol... I think I have an old saucepan (pan/pot) somewhere.... hmm.... heatsink/case..
#82 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#83 | |
frugal-phile(tm)
Does anyone have a take on whether you'd need to make any changes to pop in an 1875 into the Thor circuit? dave
#84 |
I've listened to an inverted gainclone for almost a year and there are some things everyone should know before their expectations get sky high.
The gainclone is as fussy about speakers as my SE valve amp. It plays great with my Lowhters and Tannoy Golds but is totally pathetic with my SF Signum. The SF is not a difficult load, having 1st order crossover and it can be very enjoyable even with a little 10W EL84 pp amp but with the gainclone it's vurtually unlistenable. And to all who seriously compare gainclone to a good SE valve amp, please guys lets get down to earth. cheers peter |
#85 |
Banned
What about the LM3886 amp IC?? or is that a no-no cos its got a mute circuit?? can I bridge to gainclones??
#86 |
frugal-phile(tm)
Peter,
If i get it correctly this is the as-built (i've added the optional 1,5k load resistor in blue)? dave
#87 |
Although i'm a different Peter, the 1.5k resistor is not doing much connected to ground. It should go -Vcc
#88 | |
frugal-phile(tm)
dave
#89 |
Dave: You can switch LM1875 instead of LM3875, but you'll need power xformer with lower sec. voltages (2x18V). Also, I had some difficulties with DC offset (it was 300-400mV) so you'll probably need adj. resistor +cap. at positive input to ground. But it sounds as good as LM3875.
#90 | ||
On Hiatus
Found this article mentioned in the Forum. It is about parallelling LM3886, but could probably be valid for other chips. Four LM3886 gives more than 200 Watt out! Also Schematic DC Electronics -App Note - PARALLEL-BRIDGED CONFIGURATION USING LM3886 This is Thorsten's comment on that article: Quote:
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| JLH v Gainclone? | Jezz-the-Fezz | Solid State | 5 | 12th December 2005 12:08 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 07:58 PM |
| Page generated in 0.11494 seconds (82.36% PHP - 17.64% MySQL) with 11 queries |
