Old 28th February 2003, 02:52 PM   #881
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: having cake and eating it too
Originally posted by David B
Some have suggested here that relatively high capacitance in the powersupply is good for bass and not so good for mid/high, and vice versa for low capacitance.
I believe the people who suggested this didn't try it out in a real environment. Instead of speculating, build it, connect low capacitance, then big capacitance and let your ears decide. It is that simple.
I used to built stuff by choosing parts according to my likening. I used to think: this part looks good, so it must sound good too. I never bothered to to listen. Recently I started to listen when choosing parts. And it makes all the differnce.
I checked my original PS yesterday and MUR860 from Motorola seems to be even better than MUR1520 from IR. And adding 4.7 BG N beside the bridge definitely improves highs (less harsh). Placing 1000u BG right after bridge degrades sound. 1000U BG on ea. rail per chip is definitely enough in certain gainclone arrangements.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th February 2003, 03:13 PM   #882
Algar_emi's Avatar
Default Peter Daniel Gain Clone Schematic
Here a complete schematic schematic of Peter Daniel Gain Clone Version in PDF format including the power supply. Let me know if you have any comment.
Old 28th February 2003, 03:15 PM   #883
Algar_emi's Avatar
Default Peter Daniel Gain Clone BOM
Here the parts list with prices and distributors.
Old 28th February 2003, 03:24 PM   #884
Default Re: Peter Daniel Gain Clone Schematic
My PS wiring is different. I run ea. secondary to a separate bridge. Secondaries and bridges are not connected inside the PS. I also run separate grounds for + and - rails and they connect only at amps star ground. According to your schematic there is no reason to run separate ground wire for + and - rail, because they are common (connected at PS).
www.audiosector.com
Old 28th February 2003, 03:27 PM   #885
Default Re: Peter Daniel Gain Clone BOM
You have $45USD for Cardas speaker cable. What is it for?
www.audiosector.com
Old 28th February 2003, 04:15 PM   #886
Algar_emi's Avatar
Default Cardas Wire
I was expecting to use short lenght pf Cardas Crosslink speaker cable for the Power cable between the power supply and the Amp. This is the only OFC copper cable that I can easily get. Price is around 8$ per feet.
Old 28th February 2003, 04:23 PM   #887
Steve Eddy's Avatar
Default Re: Cardas Wire
FYI, wirewrap wire is OFC and is readily available.
Oh, and considerably less than $8 a foot.
se
Old 28th February 2003, 04:32 PM   #888
$8 a foot is definitely too expensive and probably not practical as well. I'm using Kimber 4TC which has exactly 8 wires, some of my friends actually prefer regular silver plated copper hook up wire (teflon) to Kimber as having more body and better tonal balance. Also Cat 5 cable might be a good alternative.
www.audiosector.com
Old 28th February 2003, 04:40 PM   #889
Algar_emi's Avatar
Default Peter Daniel Gain Clone Schematic Corrected
Hi Peter. Thanks for the precision on the power supply. One reason I did this schematic was to compiled all the comments on your Desing in this post. Check this version and tell me if I got your explanations correctly. Let me know if there is any other changes to do.
Old 28th February 2003, 04:46 PM   #890
Algar_emi's Avatar
Default Power Supply Wire
Thanks for your comment on the Wire. Peter, do you know a distributor of Kimber 4TC and also the price so I can update the parts list.
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Page generated in 0.12484 seconds (80.07% PHP - 19.93% MySQL) with 11 queries
