| Chip Amps Amplifiers based on integrated circuits |
#2341 |
That's pretty dang awesome.. Funny. But awesome. So who's going to make a 6 channel battery powered gainclone and stick it in a party keg? Anyone?
#2342 |
The amps have to be waterproved if beers are used as coolant! No heatsink required! Well work great for me for I like my ale not too cold!
The Butcher
#2343 | |
frugal-phile(tm)
Hope this inspires even crazier ones.... dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#2344 |
Isn't that the most interesting discovery - "BEER Cooling !" BRAVO !
#2345 |
The rising bubbles circulate the cool beer around the warm chip. That's why it works better than orange juice - more convection with the bubbles.
I found that maple syrup was too thick for effective cooling - but very tasty. KT |
#2346 | |
#2347 |
Dear Kneadle,
For me, the Show Printable Version doesn't work in two ways: 1. Thumbnails and links do not show up 2. In a huge thread like this, it still has to be done in parts because the computer grinds to a halt while the conversion from the usual format to the printable version occurs. Does anyone else have these problems? Regards, George. |
#2348 |
Hi George,
What you are describing sounds like a RAM shortage. If you're using a PC, try this: Turn off as many programs running in the background as you can. Check the program list that would normally be indicated next to your clock on the desktop. If you have a lot of programs running, e.g., Nortons programs, they will hog system resources. Even with my supercharged ex-gaming computer and audio computer, the document does slow the computer down. Now, with that being said, it may not be your computer at all; it may be the web program. I recall having to give it a couple of tries, but I did manage getting the whole thing converted. And then it took a long time to download. Nevertheless, I have the whole thing on disk, and I'm slowly but surely editing it. E-mail me privately, and I'll be glad to send you my raw download. Dave
I have a small website for my projects. |
#2349 |
hello peter,
your patek amp (this one: http://www.audiosector.com/chassis_patek_amp.shtml) is looking really beautiful. you inspired me. have you ever tried Dieter Ennemosers c37 lacquer. http://www.ennemoser.com/ http://www.ennemoser.com/c37theory.html http://www.ennemoser.com/c37theoryii.html http://www.tnt-audio.com/accessories/c37_e.html 0.5ml of Snake Oil for $59 C37 ingredient guessing i had the chance to hear two hiagra 'le monsters', one treated with c37 and the other one (almost the same components, same chassis) without c37. the diffrence was easy to hear, the c37-monster had a musical note the simple monster did not have. unfortunately, c37 laque is very expensive and i am a poor kid. but if you want to build a high-end gc, money is no object .have a nice day lilmik |
#2350 |
Hi Peter and all Gainclone builders,
I would like to share with you my experience concerning the Gainclone I have built. I have been using a nice SET amplifier (home grown) for about 7 years, the sound of which was pretty nice to me. Not very long ago I even had the chance to A/B test it with a quite expensive although not triode amp (Audio Note P2SE, approx. 3000 USD retail I believe). After a week of listening I definitely felt that there is quite a difference, the advantage in most areas (dynamics and especially information content) being on my amp's side. Nevertheless, I heard so much about the Gaincard so I went to a local dealer and listened to it. It was quite impressive, although I was listening to horns this time. (At home I use large Audio Note speakers which sound beautiful for me). So I decided I would buy a kit (premium) from Peter and build it, maybe just for fun. I finished building the kit about a month ago. When I tried it first I was actually shocked. It turned out that the SET amp is "using" a pretty thick "curtain" between me and the speakers. I could hear significantly more from the music than before. It was amazing. However, there was something I did not like perfectly. There was some sharp edge of the sound, which made it tiring to listen to for longer periods, especially at louder (I would call normal for acoustic instruments) levels. After a few weeks of experimentation, last night I found the solution. Until yesterday, I was using the (pretty expensive ) Audio Note cable I used with the triode monster. Yesterday I thought: what if I change those cables with something similar to what 47Lab suggest. I had at home some Cat5e UTP cable so I took it apart and installed single wires of the 24 AWG cable. Guess what: I was shocked again. Last night was the first occasion that I could actually hear acoustic instruments and players making music in space. I had the feeling I was not listening to an electronic music reproduction device but I could actually forget about it. The last thing I would like to add is that for more that 13 years this was what I have been searching for. In 1992 I was at a HighEnd show and listened to a full Audio Note chain, including the famous Ongaku and other extremely expensive stuff. Then I absolutely felt that there was no device at all, only music. However, because the total price of that suff was well over 100 000 USD, I thought I would never be able to come close to that. It seems that this tiny little amp helped a lot in that. Sorry for the long post. I know it is not usual to write so long but I had to tell you what I experienced. Szabolcs PS. Thanks Peter for the kit! |
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| JLH v Gainclone? | Jezz-the-Fezz | Solid State | 5 | 12th December 2005 12:08 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 07:58 PM |
| Page generated in 0.17016 seconds (64.79% PHP - 35.21% MySQL) with 11 queries |
