This is not just another gainclone
Old 20th March 2003, 04:14 PM   #1381
Philo is offline Philo  United States
MatttCattt,
Can I ask why youare limiting your current? I have both 541 and 549 prototypes set up now and and just shorted the leg. The amps sound great and have had no problems!
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 20th March 2003, 04:19 PM   #1382
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
This is not just another gainclone Send a message via AIM to Peter Daniel
Hi Philo,
I'm currently building OPA549 amp. The rails can't go higher than +/-30V and pins 6 (ref) and 8 (I lim) connect to ground, right? Are you using inverted, minimized config.? Any other areas worth consideration?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th March 2003, 04:24 PM   #1383
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Originally posted by Philo
MatttCattt,
The 549 is current limited at 10A when you short I_lim.
The 541 in not limited at all when you do this. You won't have a problem with this approach until the you overdrive the amp or short the outputs. If the output of the 541 is shorted, you will have your rail voltage over you speakers If you draw more current than adviced, the chip may go up in smoke, and your speakers might be
Mads K
Old 20th March 2003, 04:41 PM   #1384
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Originally posted by Peter Daniel
Hi Philo,
Whilst we wait for Philo's response, I thought I'd share my experiences.
I connected ref and lim to each other, then to ground, left the status pin floating, and used the minimised inverted config with the addition of adding back the 1uf cap across the + & - pins.
I used (for testing only) a 75VA 18-0-18 AC traffo, as my bigger 300VA that I use for my LM3875 and OPA548 at 24-0-24 AC seemed to cause the inbuilt protection to cut in, even though it gave only 28.5V regulated
(edit) I meant to say 22-0-22, not 24-0-24
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 20th March 2003, 04:56 PM   #1385
That's what I plan to do. As I recall you mentioned it sounds better than LM based amp. Did you try TDA7294?
www.audiosector.com
Old 20th March 2003, 05:32 PM   #1386
pinkmouse's Avatar
Not yet, no money for hobbies at the mo...
I think I might have also have changed the value of the feedback resistor, but I can't remember why, and what to, and I'm away from home at the moment for a few days so I can't check!
Old 20th March 2003, 05:33 PM   #1387
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
from Peter Daniel As I recall you mentioned it sounds better than LM based amp. Did you try TDA7294?
Now that I've finished my LM3875 based GainClone, I'll go back on my TDA7294 based amp so expect news from me soon.
Just to make a short story, I had some problems with TDA7294 concerning oscillation and mysterious explosions (I finally found out that it was due to overvoltage hmmm hmmm).
The TDA7294 has very impressive dynamics and detailed sound (not to mention high output power. If more power is needed, there's the TDA7293 which accepts higher voltage rails and can be bridged using several 7293 ICs)
Old 20th March 2003, 05:34 PM   #1388
Bricolo is offline Bricolo  France
Bricolo's Avatar
AFAIK, this chip is possessed by evil
Old 20th March 2003, 05:36 PM   #1389
Bricolo's Avatar
did you manage to solve them?
Old 20th March 2003, 05:57 PM   #1390
Bricolo's Avatar
Default MKP caps
My local resealer hadn't MKP caps, he gave me 0.1uF MKH istead
are they also good? I don't know what does those caps name mean
This is not just another gaincloneHide this!Advertise here!
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 04:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 01:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 08:58 PM
