This is not just another gainclone
Old 5th March 2003, 09:31 AM   #1001
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
sorry, also had to do this, 1000th post in this thread!
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 5th March 2003, 09:35 AM   #1002
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Now go back to bed
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 5th March 2003, 10:32 AM   #1003
Bricolo is offline Bricolo  France
Bricolo's Avatar
what can put my amp in oscillation?
zeno: I have no scope, and no light bulb
but I used an Ampmeter on the supply rails, and it draws 0.3A at iddle, bot not always
sometimes it's not, and a little input signal during 1/2 second then stop, then it's 0.3A
Old 5th March 2003, 11:00 AM   #1004
protos is offline protos  Greece
protos's Avatar
Well it shouldn't get hot at all with no input and no output.99% it's oscillation accordind to the tradition here.Check all your connections then since it seems you don't have the input pot tie a 50k or so from the inverting input to ground.
Old 5th March 2003, 11:01 AM   #1005
zeno is offline zeno  Europe
If I am right, you don't have a pot on the input? (Hence the earpads )
Did you use the original shematic (National datasheet or the 'inverted gainclone') or the reduced Peter D's schematic?
Leaving out components might make the circuit more sensitive to osccillation and instability.
Is it better when you shield the circuit? (You should be able to measure the temp of course)
Marc
Old 5th March 2003, 11:03 AM   #1006
Bricolo's Avatar
I'm using a 10K pot now (I can put the earpads out of my ears now )
I'm using peter's minimised gainclone shematic (but with no input cap for the momment)
Old 5th March 2003, 11:26 AM   #1007
Bricolo,
Check post 294 in this thread.
Actually the thread we are in now
Marc
Old 5th March 2003, 11:45 AM   #1008
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
Here you can find that post from Mr. K. Wang...
http://www.diyaudio.com/forums/showt...&pagenumber=20
Fedde
Old 5th March 2003, 12:10 PM   #1009
Bricolo's Avatar
http://www.diyaudio.com/forums/showt...;pagenumber=20
Fedde
since I use a pot now, my -in is connected to ground with the 10K resistor, and the 10K pot
+in is directly to ground
Old 5th March 2003, 06:17 PM   #1010
Bricolo's Avatar
I've tested the amp deeper this afternoon:
It still gets hot even at low volume, and even with no input signal
but when I change the load from a speaker to a 10R resistor, the chip runs cooler
can this be an oscillation problem? how can I fiw it?
I wish I had a scope
This is not just another gaincloneHide this!Advertise here!
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 04:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 01:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 08:58 PM
Copyright ©1999-2017 diyAudio
