Old 26th November 2006, 07:54 PM   #1
Default LM338's for one channel getting way hotter than the other
Each channel is regulated separately, on totally separate boards. The only difference between the two channels is that one is using Panasonic FC's before the regulators, and one is using "R.M" caps pulled from an amp. The one with the FC's gets FAR hotter than the "R.M" board. The heatsinks are identical and before I put the FC's on I really don't remember either getting that hot at all.
So really, I am just curious as to why it's getting so hot? Could it actually be something to do with the FC capacitors? There doesn't seem to be any issues, even playing with the volume on the pre all the way up, and both boards are giving the same voltage outputs (+/-28.5v) and have the same voltage being fed to them (~35v after the bridge rectifiers).
I'm confused [ again ]
Old 26th November 2006, 11:56 PM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Voltage rating of the caps????
Old 27th November 2006, 12:35 PM   #3
50v
Old 29th November 2006, 01:13 AM   #4
You stated that you are using two regulator boards, so I assume both regs are running hot on one channel.
Have you tried disconnecting the amplifiers to see if the regs run hot without a load?
Perhaps one of the amplifiers is oscillating.
Writing is good exercize for the texticles!
Old 29th November 2006, 09:36 AM   #5
That's right, only one of the boards is running hot.
I will try disconnecting the amp board from it hopefully later and let you know if it cools down, though I wouldn't have thought oscillation would have been a problem. The two amp boards are identical, and the other regulator board doesn't get hot. Along side that the amp board connected to the regulator board that is getting hot.... isn't getting hot at all, which is supposedly a sign of oscillation
Old 29th November 2006, 08:20 PM   #6
Swap the amps... with their respective PSU boards.
Amp-A to PSU-B, and Amp-B to PSU-A.
See if the same PSU runs hot, or when switching, the other PSU shows the same symptoms. This way you can isolate whether or not it's the PSU or the AMP.
Simple diagnostics.
Old 2nd December 2006, 06:20 PM   #7
Simple diagnostics.
I put the other amp board on the hot channel, still gets hot. Doesn't seem like the grounding made any difference after all either!
Maybe it's just this capacitor "burn in" doing it? I could swear with the old caps it didn't get this hot... hm...
Old 2nd December 2006, 06:54 PM   #8
CarlosT is offline CarlosT  United States
Put in some new caps? Re-check the polarities?
Old 2nd December 2006, 08:11 PM   #9
The caps on that board are brand new Or did you mean put the old caps back to see if it is the caps doing it?
Polarities are OK, they haven't exploded
LM338 Regulated PS Puffin Chip Amps 6 22nd November 2008 05:40 PM
PCB: LM338 Regulated Snubberized PSU yusuf Power Supplies 7 27th March 2007 01:45 PM
Burning LM338 seftali Chip Amps 15 22nd February 2007 06:21 PM
Cheap LM338's. steenoe Chip Amps 0 8th December 2004 05:39 PM
about lm338 rulezzz Chip Amps 1 5th January 2004 08:21 AM
Page generated in 0.23906 seconds (39.22% PHP - 60.78% MySQL) with 10 queries
