Weird Voltage readings after rectifying Weird Voltage readings after rectifying - Page 2 - diyAudio
Old 27th November 2006, 07:23 PM   #11
kvholio is offline kvholio  Netherlands
kvholio's Avatar
+- 43 volts is too high for lm4780.
Read the datasheet...
With kind regards,
Klaas
Old 27th November 2006, 08:44 PM   #12
superR is offline superR  Netherlands
those voltages were measured while nothing was connected. I gues the voltage will drop when connecting the amp. And btw, it's just 2 volt over the max specified voltage. Can that do any harm to the amp?
Old 28th November 2006, 07:20 AM   #13
Go and study the datasheet.
Going to the limit invites lots of problems, going beyond the limit is asking for trouble.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th November 2006, 09:36 PM   #14
Minion is offline Minion  Canada
You might try regulateing the Voltage down a Bit, to say 35v, It will give you better performance as there won"t be Voltage Fluctuations and it solves the problem of the Voltage being a bit to high....It will also cost a bit more as high current regulators can get a bit pricey and will make the PSU a bit harder to build but it will be worth it in the end....
Good luck
Weird Voltage readings after rectifyingHide this!Advertise here!
scope readings east electronics Solid State 27 6th March 2009 12:08 PM
Voltage readings on Bal Line stage Main Board Zapped Pass Labs 6 25th July 2005 06:42 PM
DIY Readings... Remedial Instruments and Amps 6 30th June 2004 01:00 AM
Weird, Less noise with more voltage. dkemppai Solid State 17 14th January 2003 01:46 PM
diode readings sriegel Solid State 2 21st January 2002 10:55 PM
Copyright 1999-2017 diyAudio
