Old 22nd November 2006, 01:08 PM   #1
ashok's Avatar
Default LM3886 at 40 volts ??
Before the flak starts let me make a small clarification.
I want to drive a 16 ohm load !
So this is close to its max supply ratings but within the dissipation ratings and well within its current rating.
Will it withstand it or break down immediately or after some hours of use ??
AM
Old 22nd November 2006, 01:25 PM   #2
traw is offline traw  United States
I've run them up to 41 volts into 8 ohm loads. Let it run for days. I like how they sound on high voltages, really open up. Just have securely heatsinked.
Old 22nd November 2006, 01:42 PM   #3
tlmadsen's Avatar
I dito with traw.
Using a 30V AC transform is perfect. Just remember massive cooling.
Unloaded they easely take more than the 42 V DC statet as max.
Thomas
Old 22nd November 2006, 01:48 PM   #4
jackinnj's Avatar
you're close to the edge for 8 ohms, OK with 16 as Pdmax is about 20 watts -- make sure that your impedance is actually 16 ohms, however.
the amp does perform better with higher rail voltages -- this is easy to demonstrate if you run the power supply from a variac and measure THD vs rail voltage.
Old 22nd November 2006, 03:10 PM   #5
I have this odd notion that most amps perform better into higher loads.
I suspect this applies even more so with a chipamp.
I think your 16ohm idea could be heavenly.
No, I don't mean dead, buried and gone to the next life!
regards Andrew T.
Old 22nd November 2006, 03:25 PM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
double the speaker impendance = half the distortion.
Old 22nd November 2006, 06:57 PM   #7
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice Send a message via Yahoo to DJ Exprice
I'd say you could even go to 48 VDC if you wanted to! Just make sure that you remember to use the AC to DC formula:
VDC = 1.414 * VAC
OR
VDC / 1.414 = VAC
OR
VDC * 0.707 = VAC
OR
VDC = VAC / 0.707
(I love that Formula! )
So:
48VDC ? 33.9VAC
Old 22nd November 2006, 07:04 PM   #8
if you intend pushing the supply voltage to the limit, then do keep in mind that the transformer has inherent regulation (important if one channel gets disconnected, even if only temporarily) and that the mains input voltage varies (normally within the tolerance allowed by the authorities).
The maximum PSU voltage assuming highest voltage conditions can be very much higher than the nomimal voltage predicted using that formula.
Take care to do all the sums and not just the ones you like (the answers for).
regards Andrew T.
Old 23rd November 2006, 10:16 AM   #9
ashok's Avatar
Thanks for all the suggestions.
So I guess if I use a +/- 40 volt regulated supply and use a 16 ohm load I should be OK and not expect any kind of failure of the chip.
The regulated supply should take care of supply sag from the transformer and capacitor on load and also mains voltage surge if the mains does go up by say 15 % (?) from the nominal value .
AM
Old 23rd November 2006, 11:22 AM   #10
that sounds sensible.
However, building setting-up and bebugging a regulated supply that in the end sounds good is not easy.
A cheaper and much quicker alternative would be line fuses and a crowbar to ground to protect your chips from severe supply overload.
regards Andrew T.
dc volts mike dodd Chip Amps 13 10th August 2009 03:45 AM
LM3886 on 14.6 volts wolf-audio Chip Amps 15 13th April 2009 02:46 PM
12 volts to 6 Dan2 Car Audio 36 23rd November 2007 06:35 AM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 02:52 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
Page generated in 0.16834 seconds (50.49% PHP - 49.51% MySQL) with 10 queries
